Results 1 to 12 of 12
Thread: diff ratio selection
    Default diff ratio selection
    with the stock sprinter diff making all sorts if whines, i figure now is a good time to swap to a hilux diff. however im not realy sure what ratio would be best suited. at the moment the setup is 4agte - t50 - S series diff. the car is a street car, but it will see the occasional trip to the strip. suggestions?
    Default Re: diff ratio selection
    4.1 is pretty good for the street. Depends how short you want 1st gear but i'd prefer about 4.5 myself.
    What has it currently got & are you happy with it?
    Aug 2006
    i would think that 4:3 would be the best option. for your needs
    somewhere in the early 4's would be appropriate, you dont want too short otherwise youll never get good speed out of 1st and 2nd.
    i have a 4.3 ratio out of a hilux here if you are intersted let me know.
    Turbo boys, use the torque I think a 3.9 would be ideal....maybe even a 3.7. Still short enough to be streetable off boost but will 'load' the engine up nicely to get you on boost. More time in gear as well.
    If you can get access to Cartest (quite an old car sim program) i have found this very accurate for diff ratio selection. All my cars have run very close to the predicted times at the stated ratio so you can then test a heap of different ratios to see what they'll do for you.
    For my 18RGT a 3.5 was the go.
    For the GT8 i should be running a 2.8:1 but can only get a 2.9:1 which is what i currently use in full TRD form to great effect.
    Junior Member Backyard Mechanic SIKTOY's Avatar
    [QUOTE=JustenGT8]Turbo boys, use the torque I think a 3.9 would be ideal....maybe even a 3.7. QUOTE]
    Good luck finding a 3.7
    reputation is nothing knowledge is everything
    RA23 1GGTE 12.3@110mph
    1980 RA40 now getting a 1G with new picsLOOK
    Don't argue with an IDIOT.He will bring you down to his level and then beat you with experience!
    i would have thought 3.7 or 3.9 as well
    whats the point of waiting for turbo lag if you have to change gears so often (ie, into 4th before 100)? kinda defeats the purpose
    Quote Originally Posted by SIKTOY
    ring gear only
    http://page8.auctions.yahoo.co.jp/jp/auction/h42960289
    2.9???
    http://page4.auctions.yahoo.co.jp/jp/auction/d68737264
    edit: these might be T series...
    ha ha smartie bum
    ha ha smartie bum
    3.9, 4.1, 4.3, 4.55 and 4.77 are all much easier to get tho ... in T series...
    cheers for the responses so far, after calling a heap of wreckers today (none of whom could help me out with a complete rn41 hilux diff) most of the centers i can find are 4.1
    my main problem is i havent realy had a chance to drive the car hard yet, it curently has a 5000rpm rev cut and is running about 5psi of boost, as it was only a run in tune, so im not realy sure if imhappy with the current ratio or not!
    it curently has the stock s314 coded diff. i cant figure out what ratio that is?
    http://www.toymods.org.au/~rod/Techn...ID%20Codes.doc
    right im dumb, i have 3.9s according to the link i gave myself!
  1. changing the gear ratio's in hilux diff.
  2. Diff Ratio Good Link
    Last Post: 13-10-2006, 06:55 PM
  3. How to work out what diff ratio you have?
    By BlackSupra in forum Tech and Conversions
    Last Post: 11-06-2006, 11:01 PM
  4. XT130 diff ratio swap
    By dale30 in forum Tech and Conversions
    Last Post: 14-02-2006, 09:23 PM
