Page 3 of 3 FirstFirst 123
Results 31 to 42 of 42
Thread: 1G-GTE rebuild (parts)
    Junior Member Carport Converter ecko's Avatar
    May 2007
    tasmania
    Default Re: 1G-GTE rebuild (parts)
    2 1gge gasket kits on ebay atm.
    Junior Member Backyard Mechanic VasH's Avatar
    Quote Originally Posted by ecko View Post
    nice find man i need a full set too!!
    +rep
    1989 JZZ20 Soarer, 1JZGTE - The Project
    1984 YN57 Hilux, 4Y - The Daily
    Junior Member 1st year Apprentice moggie's Avatar
    Feb 2009
    Does someone want to go halves with me?
    Also is the 1gge head gasket the same a 1ggte?
    SA63 Coupe Restoration - Finally have the motivation to finish her.
    Quote Originally Posted by moggie View Post
    ill goes halves with ya man if your in qld. i live in chermside.
    should be the same looking at the pic its the same as the old one i have in the shed.
    Feb 2009
    For rings on the gen 3 with compresion rings 1.5mm, 1.5mm and Oil ring 4mm. They are the same size as the 2M engine, For a set of 6 chrome moly rings was $100. That is from precise engine rebuilders on the gold coast.
    Feb 2009
    Rings for a gen 3 1g with compresion ring thickness 1.5mm, 1.5mm and oil ring 4mm you can use 2M rings.
    I got a chrome moly set for $100 from precise engine rebuilders
    double post lol?
    but awesome work on finding some dude, im gonna hit them up on monday and get a set
  8. #38
    Feb 2009
    wtf i have no idea what happend on the double post it didnt show up the first time i typed it in.
    I tred the rings today and didnt fit, but I think they gave me the wrong box becuase they are totaly wrong. Il hit them up monday and see what the go is.
    They also said not to use the ACL race series bearings as they are 4 times more likley to bind on the crank and spin a bearing.
    They said to use aluglide from ACL or king bearings. They use the aluminium ones from king in all there motors.
    2 sets of king bearings for 3sgte (1ggte mains) would be about $100 which is way cheaper then repco trade price.
  9. #39
    Nov 2009
    W.A
    I work for Veale's and we're a supplier of ACL and they don't do gaskets for 1g's, already checked as im in the process of rebuilding mine. Couldn't find any steel head gaskets with any of my supliers. I went with genuine toyota as iv'e been told the toyota head gasket is good for about 16psi.
    These are genuine toyota gasket part numbers given to me by Toyota for my GZ20 1ggte
    Head gasket T1121388341
    Exh manifold T1717388340
    Int gaskets T1717788302 between head and butterflies
    T1717988341 between butterflies and plenum
    Exh manifold T1717888340
    to turbo's
    Rocker cover T1121388341
    Im only rebuilding my head so I dont have a full kit number or anything from the head down.
    Genuine toyota water pump T1610079065
    Distributor o-ring LD8201
    Distributor cap 19101-88340
    Head bolts 90110-10003
    I got all this with timing cover gaskets, timing tensioner and idler pulley (cant find part numbers right now) for around $750 trade. Not sure about retail.
    Hope this can be of some help.
  10. #40
    bummer, let us know when you get it all sorted as ill get the part numbers off you so i can get me some
  11. #41
    Toymods Club Member Backyard Mechanic auto351's Avatar
    Nov 2007
    N.S.W
    Moggie,
    Have you found out what was wrong with the rings?
    Can use Toyota 2M rings for 1GGTE Gen3 with ring measuments;
    Compresion ring 1 = 1.5mm
    Compresion ring 2 = 1.5mm
    Oil RIngs = 4mm
    Set of 6 Chrome moly rings set me back $100
    also you still have this posted under "Toyota's Interchangable Oddities.... (TIO#)"
    http://www.hastingsmfg.com/RingFinde...OYOTA&AddText=
    Listing from Hastings 1G fitted with 2 * 1.5mm comp & 1 * 4mm oil but 2M fitted with 2 * 2mm comp & 1 * 4mm oil
    The only match is the 4KE, where as the 4KC is different again
  12. #42
    Well, by my measurements the gen 3 pistons I have are 1.5 top ring, 2mm mid ring and 4mm oil ring. Holding in my hand what is hopefully a matching set of rings, if they fit I'll post part numbers. Next question: does gen 3 crank fit into gen2 block... And if so, what bearings suit the gen3 big end?
    -rm
