this may be useful for the rings
http://www.hastingsmfg.com/RingFinde...OYOTA&AddText=
Here's some usefull info for anyone doing a rebuild, Apart from acl, ndc do bearings for the 1g and the supplier is listed bellow. Ive also been speaking to an engine recon place here in brisbane about hastings rings but i need to measure them up or take em in so he can match a set. He has had them in the past. Once i get a part # ill re-list it here.
ACL BEARINGS, 3s and 4k (to suit 1ggte) - acl 0363244600
MAINS
3sgte - 5m8361h $85
RODS
4k - 42mm shaft 45mm tunnel - 18mm wide - part # 4b1101 , 44mm 47mm
acl 0363244600
NDC BEARINGS 1ggte - MD spares 0395530388
RODS
ndc part #'s
cb1402gp 18.9
cb1420gp 18.18 wide
MAINS part #'s
ms1402a all the same 55mm shaft 59.02mm housing 19.2mm wide
ms1420 #1 is 22.2mm wide 2-7 are 19.2mm
1989 JZZ20 Soarer, 1JZGTE - The Project
1984 YN57 Hilux, 4Y - The Daily
from what i have learnt so far 4k corolla engines use the same piston/ring combo
also for sizings of bearings
http://www.king-bearings.com/cat/panel/pan2001.htm
good find, i have a feeling though the rings for the 1gge might be different. The rings are different for the 1ggze and the 1ggte so im thinking the 1gge could be different as it runs higher compression. I will get mine measured soon enough to find out![]()
does anyone know the factory compression ratio's for the 1g this may help us some what
have spoken to a couple of guys that have rebuilt the 1ggte, they have sucessfully run 4k pistons and rings, majority of the compression is based on piston crown and cylinder head cc design rings only play a really small part. can always file the gap open in them anyways if need be
1985 RT142, 1GGTE,.now with t67-25g
2009 Ford Fiesta LX
1970 Ford Cortina MK2 440
good luck with thati think you will find 4k rings dont fit 1ggte's
KE38 - 2TG
MS65 - 1UZ
same diameter and thickness, seems reasonable they would work
2009 Ford Fiesta LX
Since the 1G pistons have valve releifs cut into them, I'd guess 4K pistons would either interfere, or not interfere and leave a low comp.
instead of fucking around why not just get a set of forged piston made and throw them in![]()
cheers steve,
1ggte, 11.22 @122mph
Does anyone know what comes in the genuine toyota gasket kit for the 1g. ie. does it come with all the crank seal and cam seals ect. Also does the valve stem seals come with it? Iv read somewhere that 4age valve stem seals fit the 1ggte can anyone confirm this?
Ash
SA63 Coupe Restoration - Finally have the motivation to finish her.
HI, I'm interested in this also, I'm fairly sure the 'interchangable oddities' thread had something long ago about the 4AGE stem seals. Need some for my 1GGZE.
A lone crusader, in a dangerous world of low reputation...
ST141 Corona, VZN130 4Runner, 4AGE KE70 Pan Van
18RG RA28
1GGZE RA28
valve stem seals come with the kit as well as every other seal, gasket and copper washer on the whole motor![]()
cheers steve,
