Results 1 to 3 of 3
Thread: 22R-E Torque Specs Required
    Default 22R-E Torque Specs Required
    Good morning Gentlemen.
    I require, should any of you have them floating around in your head, the following torque specs for a 22R-E:
    -Rocker Cover bolts
    -Flywheel bolts
    Regards,
    Javal.
    Default Re: 22R-E Torque Specs Required
    Torque settings as per Toyota engine manual. Flywheel bolts 73 - 86 ft-lb
    Rocker cover bolts 3 - 5 ft-lb
    Alex
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
    Thankyou muchly.
    As it turns out, i guessed pretty good
    Torqued them up to 110nm, which is almost bang in the middle of those two figures.
    Rocker cover nuts were done up to 'yep'.
  1. 1JZ Sump swap torque specs
    By Sideways Supraboy in forum Tech and Conversions
    Last Post: 02-05-2009, 08:06 PM
  2. 3SGTE ARP Flywheel bolts - Torque Specs?
    By Howieau in forum Tech and Conversions
    Last Post: 22-10-2007, 06:48 PM
  3. 7m engine torque specs
    By Bored? in forum Tech and Conversions
    Last Post: 26-04-2007, 10:55 AM
  4. Clutch LSD => Torsen LSD
    Last Post: 21-10-2006, 02:14 PM
  5. st162 bolt torque specs
    By Bahnugget in forum Tech and Conversions
    Last Post: 30-01-2006, 09:53 AM
