Results 1 to 3 of 3
Thread: st162 bolt torque specs
    Default st162 bolt torque specs
    Hey guys, i searched old and new and still have no joy... i was wondering if somebody knows (or has a manual they can quote/scan) to tell me the bolt torque settings for the front strut top bolts, exaust manifold nuts annd the big mumma hub nut.. i think thats all i need to know... rep points will be given
    edit: also, do the nuts from the steering knuckle to the strut have a certain torque? if so i would like these also
    Default Re: st162 bolt torque specs
    Straight from the Haynes manual.
    with strut top bolts, do you mean the three nuts ontop of the susp towers? if so, they are59ftlb.
    exhaust manifold: 32ftlb
    hub nut: 137ftlb
    steering knuckle to strut is 152ftlb or 188ftlb if its an 89mdl.
    I just put new struts in recently myself. i just did the strut bolts up really tight! get heaps of leverage on the spanner/socket. also drop the car down 1st then do up the top strut tower nuts when there's weight on it.
    Junior Member Domestic Engineer NeoNasty's Avatar
    EEP! No, do it to the correct settings. Its not uncommon to strip the bolts and/or root the strut top! Dont evaarrr use the rattle run either. Do it properly or dont do it at all. These are components that you dont want breaking while your on the move.
    By The Witzl in forum FAQ
  2. 18RG info and specs need 2tg and 3tg
    Last Post: 08-04-2009, 04:29 AM
  3. Clutch LSD => Torsen LSD
    Last Post: 21-10-2006, 02:14 PM
  4. Will Front RA60 Discs And Calipers Bolt To Ae86 Struts??
    By nos4ag in forum Tech and Conversions
    Last Post: 14-01-2006, 04:12 PM
  5. flywheel bolt torque
    By ae86 slide in forum Tech and Conversions
    Last Post: 30-12-2005, 09:05 AM
