You diff is a G series supra diff right? I just pre-fitted (test fitted) a G series Torsen LSD center into a G series turbo supra diff housing that used to have a clutch type LSD center in it. The splines, crown wheel and pinion all line up perfectly. So I am unsure if this is true or not? I know that the clutch type LSD was from an import car.
I also found that a hilux (live axle diff) center is interchangable too. Cause I just did a test fit of the same G series torsen into the hilux/hiace diff housing and everything lined up perfectly (this was after I was told that the diff center from a supra needed machining down first to be able to fit a hilux).![]()
Hope this helps you out?
Did you end up getting your diff from John yet? Or are you still waiting on it? How much did you pay for the Torsen if you dont mind me asking? I just sold my torsen in perfect condition (almost new) for $500 inc.postage.
James
PS: Does he have anymore of them coming or in stock? If you know he does (dunno if he updates the website regularly) then let me know, cause there are two other people that missed out on my sale that are still chasing them. Thanks
). It is out of a JZA70 Supra. I purchased it complete in the original housing.
