Results 16 to 30 of 53
Thread: MX83 Grande Stereo Install
    Default Re: MX83 Grande Stereo Install
    ashtray is where the dvd screen goes.
    Easy you wire the aerial to the stezza
    May 2006
    tas
    it is??
    please elaborate
    that little flap pocket looks kinda funky
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    Wire it to the power antenna output on the stezza.
    Alternatively you wire it to the remote wire for the amp but it will go up when stezza on and down when stezza off.
    Just finding the correct wire is the issue.
    There is a thread about it on the Cressida forums - http://forums.toyotacressida.net/for...ad.php?t=42589
    For those that dont have a a login:
    Quote Originally Posted by wumpagrande92
    NOTE: this is for the 1992 Australian MX83 Grande, there could be differences between models and countries.
    t's not so hard, just take your time so as not to break any clips or scratch anything.
    Step 1: Remove trim around shifter.
    Step 2: Remove trim under instrument cluster.
    Step 3: Remove sattelite controls.
    Step 4: This comes out as a whole unit.
    Step 5: Which is held in place by four 8mm bolts.
    Step 6: The headunit is held in here. Most aftermarket headunits will have holes that will line up.
    Here are the wiring colour codes:
    Power Connections
    Constant 12V+: Blue/Yellow
    Switched 12V+: Gray
    Ground : Brown
    Illumination : Green
    Antenna Trigger : Black/Red
    Front Speakers 5 1/4" Doors
    Left Front (+) ink
    Left Front (-) : Purple
    Right Front (+) :Light Green
    Right Front (-) : Blue
    (If front tweeters fitted, colour is the same)
    Rear Speakers 6 1/2" Rear Deck
    Left Rear (+) :Black
    Left Rear (-) : Yellow
    Right Rear (+) : Red
    Right Rear (-) : White
    I can't find the info on how to make the standard elec. ariel work yet.
    And the electric aerial:
    Here are the wires you need to use to get the electric ariel working.
    Join the Green/White stripe and the Black together then join to your Blue (Usually) on your head unit ariel control wire.
    Hope it helps.
    May 2006
    tas
    thanks!
    i hope that these enough original wiring there.
    had a after market head unit before and i think its a little hacked up...
    -JZX83 in the build
    <3 7M sludge pump
    So im bumping this again.
    Anyone got a pic of the insertable pocket which goes in place of the stereo controls?
    May 2006
    tas
    that pic has the stereo controls??
    or do you mean a din pocket that goes under/on top of a single din head unit?
    apparently it isnt a direct replacement also, these a gap or some shit. i plan to remove the buttons and bog over the holes for them.. sand and paint etc too.
    -JZX83 in the build
    <3 7M sludge pump
    Yea i just had a look over on toy cress . net and it shows how not bolt in it is.
    Which is gayer than aids.
    You have to replace the whole surround. Hmmm.
    Whos using a double din stereo or single dinn?
    May 2006
    tas
    im using single din.... whyy?
    -JZX83 in the build
    <3 7M sludge pump
    you mean this one up the top?
    Yeah thats it, but is i read up i would need to get the whole surround aswell as the pocket setup.
    SO wtb gl surround and pocket
    Nup, just need the pocket. I got a pocket for my GLX and is a direct pop in replacement for the GLX stereo controls.
    Quote Originally Posted by takai View Post
    So whered you get yours from?
  1. MX83 Grande with Jza70 Auto
    By nemesis86 in forum Tech and Conversions
    Last Post: 22-09-2006, 08:58 PM
  2. GUIDE: GXE-10 IS 200 Stereo and Phone Installation
    By GTtwin in forum Tech and Conversions
    Last Post: 04-08-2006, 09:38 AM
