Page 3 of 7 FirstFirst 12345 ... LastLast
Results 31 to 45 of 91
Thread: Cracking the Crank Pulley
    Mar 2008
    inner west syd now!
    Default Re: Cracking the Crank Pulley
    i has proof of otherwise
    seems to be quite a large typo.
    its from a recent Repco catalog
    LOL, take em to whatever board it is for false advertising
    maybe they forget the decimal point?
    Mar 2008
    inner west syd now!
    i think the 0 is supposed to be the small degrees type, not a 0!
    definitely typo - otherwise they'd use that stuff at the Large Haydron Collider at Cern instead of liquid helium for cryo-cooling
    like these... my old sidchrome one of these has copped many hits from sledge hammer and also broken socket when trying the starter hit on.. honduhs
    Yup, ive got something similar that came with my Repco metric socket set.
    Hasnt failed me yet.
    Dec 2008
    western australia
    ive had some tough ones too , so i made this tool up .. never failed as yet .. YOU WONT BREAK THE TOOL or bend it so go hard !!!
    it started out as a 1metre long bar but i found it to be more effective at this length just put it in upright postion and crank the starter .. it just clears the battery and smashes on the ground , cracking the bolt.
    if its a really tough one , just place it so it has more swing.
    dodgey but effective !
    Perth WA
    Unfortunately, I don't have the spare real estate to let it swing - RA23 Celica engine bay - it's like a japanese apartment in there.
  8. #38
    May 2006
    tas
    i use a welded ratchet (it i actually broke the weld on it once with a 1m pipe extention)
    any chance you have acsess to one of those big arse rattle guns that they use for truck wheel nuts??
    or trailer it to a tyre place that deal with trucks and just use it there
    so really funny/ghetto ideas here!!
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
  9. #39
    Tasmania
    ide be worried it would snap the head off the bolt...then you'd really be galloping up diarrhea drive without a saddle.
    Clint did you try the loctite freeze shit then go to town with a rattle gun? or cranking with the starter. Give it a tap or two with a hammar to release it before cranking.
    that freeze shit has saved my arse numerous times...top stuff.
    1973 TA22
  10. #40
    Junior Member Grease Monkey off-road's Avatar
    NT
    Yellow Pages-----> Tool Hire -----> 3/4" Drive Rattle Gun and Compressor to suit.
    2GR-FE 200 Killer Wasps
  11. #41
    Try tightening it up a little bit first. this should crack loose any rust/thread cement thats on the bolt. Then try undoing with the rattle gun.
  12. #42
    i snapped a small spanner, then a big one
    then a 1/4 inch breaker, this didnt work
    so then i did this
  13. #43
    Jun 2008
    1) Let's hope the bolt isn't left hand thread as I've been caught on other vehicles (mainly US).
    2) Use a 3/4 breaker bar and single hex impact socket. Hit the bar with a wooden mallet while holding it tight in the direction you want it undone. The problem even with rattle guns is there is too much metal in the crank and it will absorb the force in minor twisting and a 1/2 breaker bar will do the same. You don't have to belt the bar with all the force you can but you do have to pre-load the system with your other hand to avoid the torque damping of all the other metal.
  14. #44
    Go hire a torque mulitplier, remove the starter motor and lock up the flywheel with a pry bar. They work a treat and require little effort.
    Alex
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
  15. #45
    Perth WA
    Pulled engine and box out, then seperated box and removed clutch. Chained flywheel up, and got the big hurter with old 1/2" socket and 22mm impact socket onto the job - brokeded it, swore!
    Next was a Powerbar as shown above - brokeded it too, other people swore:
    Final straw - I hired a Mongo (6'+ 100Kg mate with a Repco 1/2" breaker bar and a desire to kill it!), added the big hurter to the breaker bar, and strained like fuck - brokeded it - the bolt from it's bastard hold on the crank thread that is! Pulled the bolt out, doesn't show any signs of "loctite or similar" adhesive, but does show corrosion on the end. I can now progress with the timing belt change! FWIW, I expected the Repco bar to break too, but upon closer inspection, the drive peice is black/hardened steel, so I'll happily add one of these items to my toolkit - and recommend one to everyone else too.
    My thanks to DrNick for your help - it was greatly appreciated.
    Fucken Cars!
  1. Crank Pulley Balance?
    Last Post: 23-10-2007, 03:09 PM
  2. 6MGE vs 5MGE crank pulley
    Last Post: 29-04-2007, 02:38 PM
  3. 4AGZE - EA Falcon Pulley Mod
    By TooF in forum Tech and Conversions
    Last Post: 15-05-2006, 01:23 PM
