Results 16 to 18 of 18
Thread: thermostats - in particular for a 7mgte
    Default Re: thermostats - in particular for a 7mgte
    Quote Originally Posted by BLACKCAT
    Your engine will run rich longer
    Run rich longer? Most cold start and coolant maps I've seen stop compensating around 60 degrees, well before 82 degrees.
    May 2006
    tas
    see if TRD make 7m ones?
    they look awfully simerlar to 4age ones.. TRD make a few different versions including a higher flowing version from memory
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    p00 powar Grease Monkey Jin~Jah's Avatar
    The dudes at the local parts place gave me an 82 degree thermostat that's apparanlty out of a Rav4
    Fitted in fine, and haven't had any issues with it - temperature usually wanders between ~80 and ~90 depending on what the thermofans are doing
  1. Using 7MGE Injectors with 7MGTE ECU
    By JZA70R_92 in forum Tech and Conversions
    Last Post: 05-02-2009, 04:48 PM
  2. 7mgte power results (6 / 5mgte's welcome)
    By mux in forum Tech and Conversions
    Last Post: 16-08-2007, 05:41 PM
