well, i had a problem similar to you in my 5m, but it was running too cold, and temps would go from 50-70 all days long, depending on how i drove, i thought it was running no thermostat, went and bought a genuine 7m thermostat ($33, wat a rip) and it is 88 degrees, i took of my thermostat cover to find it did have one, but the seals where gone, causing water to pretty much bypass the entire thing, the other 5mge had a WAX-STAT 48degree thermostat that was also fubared! my motor did its hg once i changed it to the brand new one, if you want i could give the the original one, it'll run alot cooler![]()
to answer your Q i dont know about cross-breeding, but if you go to Toyota, theyll ask for a VIN number for no fu$in reason!! so i say take the thermostat in with you and ask for something with a lower temp!!
hope that helps, chances are it wont do.
wog
