Results 31 to 45 of 49
Thread: Ra40 w50 to w57 conversion?
    Default Re: Ra40 w50 to w57 conversion?
    It sounds like the late RA40 stuff is halfway between the old W50 and the W5x range.
    Some things had migrated to the new design.
    From the looks of things, it would seem that the W50's changes were more to do with further R&D enabling lower production costs (the throwout fork went from a solid cast iron item that pretty well never wore out to a folded metal item which wears over time), and the R&D's results were just transferred to the W5x to prevent having to re-tool anything that didn't need re-tooling.
    I would guess it's all cost driven.
    Junior Member Backyard Mechanic maurice c's Avatar
    Yes we Canberra
    Heres a picture of the older style fork, pretty tuff and as stated pretty much indestructible prone to dirt and crud though.
    W57 fork, pretty much the same as the RA40 I reckon, pressed steel, can bend I reckon.
    W57 ra65 position selector. Now i'm thinking that if I want to change over to the more rearward selector position then I have to split the back of the gearbox, anybody got any experience in this area?
    Getting your missus to help bleed the brakes isn't everybody's idea of quality time.
    Yes, split the case and undo that bolt you see that.
    Slide the whole thing off and replace that selector with an MA70 one.
    Then be very careful putting it back together as its easy to knock it into a gear or two.
    Once you think you have it right, try and select all 5 gears and reverse.
    Once you verify that all the gears work, bolt everything back together.
    May 2008
    Dammit My W58 going into my MA70 looks like this I hope it fits ok and the shifter isnt to far forward
    1992 - JZA70 STOCK - SOLD
    Will need changing if it looks like that.
    Yes we Canberra
    So bascially take out the bolts from the sandwich plate and it will all slide up if the box is bellhousing down, is there anything that can fall out of the box or get misplaced when this happens? Should it be in neutral when your doing this?
  8. #38
    May 2008
    oh wells I need to the ABS mods that you did might aswell swap out the shifter part...now where can someone obtain such part?? rang up a mate he said take the whole gearbox for $500 no thanks!!
  9. #39
    Quote Originally Posted by maurice c
    Yeah, take out the 11 bolts that are in the sandwich plate, and the 6 that hold the positioner on, and the 1 small one that holds the selector to the rod.
    Then (with some force) the rear of the box will 'slide' off.
    Best to start in neutral, but it really doesn't matter. You'll see what the selector rod engages with when you get the back of the box off. When all 3 line up, thats neutral. But its common and easy to knock one of these into gear when you put it all back together.
  10. #40
    Yes we Canberra
    Seems to be some crud in the box so splitting it for cleaning is probly a good idea.
  11. #41
    May 2008
    so to convert to A70 spec shifter postion which bits will I need?
  12. #42
    The bit the green bush sits in, and the bit the white bush goes in.
  13. #43
    May 2008
    so will the w58 from the ma61 postion fit at least in the ma70 or will it be not worth the hassle. this is stopping my project in its tracks as nobody seems to have these parts and if they do they wont part with it
  14. #44
    Not worth the hassle.
    They are different for a reason.
  15. #45
    May 2008
    ah crap so Ill need to purchase another w58 shite lol. no one has any bits to give away/
  1. MA70 --> JZA70 Conversion
  2. RT142 live axle rear disks into RA40 - anyone else?
    Last Post: 30-08-2007, 11:07 AM
  3. W50 into RT81
    By gianttomato in forum Tech and Conversions
    Last Post: 17-12-2005, 12:29 PM
  4. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
