the corona callipers are fed with a short rubber line and a banjo fitting.
there is a way you can get around the bearing retainer swap.
you could make a ring to the specifications of the corona retainer.
cut a slit in it, stretch it over the ra40 axle and push the ring into the diff housing.
i think its a given that youll destory the bearings if you want to change the retainer plates. have you factored that into the swap?
