It is apparently Fuchs with some badge engineering. I am running it at the moment.Originally Posted by SYC02T
I think that if I can afford it, then I will try Royal Purple next.
d-master
you could put your theory to the test. Go to kmart buy your self some nice cheap home brand oil (change this regularly). Take your car out to a track day, I would suggest transporting it there (just in case). Then count the number of flat out laps you could do before engine damage occurs.![]()
Nah just joking.![]()
Synthetic oils are a good idea for turbocharged cars because of the temperatures the oil can withstand. The oil that lubricates the turbo gets extremely hot as you could imagine.![]()
1990 ST185 GT4 3SGTE
1991 ST184 SX 3SGTE
1991 SW20 GT 3SGTE
1998 ST215 GTT 3SGTE
2008 VDJ200 Sahara
Yeah, Had my eye on the Royal Purple. Looks good but bloody expensive.
Hope the saying goes 'you get what you pay for' goes here or is it just for the name
Dude, Royal Purple is a 100% PAO type full synthetic. I am waiting on some scans of independant testing to put to rest a few other points in this thread toOriginally Posted by SYC02T
1971 2T-B Celica TA22 ST.
1975 2T-G Celica TA27 GT
1985 3F Auto FJ62 Landcruiser
most 4 bangers are 3.5 ltrs, that includes filling the filter aswell,Originally Posted by go_the_datt
the 1g is only just over 4.....
i use castrol, magnatec semi synth, i only use it coz i get it for fweeeee!![]()
and its changed after all race meets,...
ive changed the oil 4 times in 3 months......and changed the filter once,![]()
N??? oil was put in a Lycoming 0320 aircraft engine and had a forced landing due to engine failure as two exhaust valves clogged up in the guides and stuck open. The sellers denied liability and lucky I am still alive to tell the tale.
The engineer had to hammer the valves stuck in the guide with a sledge hammer.
To get them out and they are sodium filled worth $750 each.
This story is probably irrelevent. so disregard.
The engine was a horizontally opposed 320 cubic inch 200 hp, air cooled aircraft engine so again is not relevant.
I have no idea what car oil is like but I use Penzoil or Quaker 3 state in my 3L turbo 280Z on LPG and at 5000 km the oil is like sewing machine oil clean like honey..
PS. I am told you dont put synthetic oil in brand new only real old engines???![]()
I've been using the Castrol Edge 10w-60 in the 3S. Found being the 60 an advantage as on track days it seems to retain some more oil pressure when its hot.
But being a 6.5 L sump it costs an arm and a leg to do an oil change which I try to do after each track day.
ahahahaha in my old xc falcon sundowner panelvan i used to use the FRANKLINS $8 = 4ltrs of oil,Originally Posted by d-master
but the motor had 350,000 on it and burnt more oil then fuel!.....the rings were fine, but valve guides were ROOTED...and used to blow a massive cloud of smoke for about
10-15seconds everytime you start it......LMAO!![]()
the old MINI OWNERS saying...."can you fill up the oil and check the fuel"![]()
blake![]()
no you use synthetic oil in NEW motors, as its thin and lubricates better,Originally Posted by RT104GT
you use just the usual mineral oil in older engines as its usually thicker and does burn as much....and doest leak through every tiny seal....
saying that aswell, you can get THICK viscosity full synthetic oil....but it cost an arm and a leg compared to the thiner FULL synth....
blake![]()
Since this thread is in view again I thought you guys might like to know that Gulf Western have released a new ester based synthetic with their usual top notch pricing.
Sougi S6000 - Numbah wan doorifuto oil!
http://www.gulfwestern.com.au/category.asp?CategoryID=8
Any older PF.com members on here might remember a guy called rhspecr who apparently did a lot of chemical analysis on oils for McLaren a few years back. Apparently he wrote a lot of info on the Mobil 1 site about their oils as well. He hasn't been around PF for a while, but before he disappeared he posted up excerpts from a 15k word study he performed on a number of common oils. The results of which were an interesting read.
The thread that he posted it in has since been deleted on PF.com but I have saved the docs he posted at home and can send em through to anyone who is interested in them. There's a lot of chemical analysis information in them so a lot of it was over my head, but still some useful stuff in there.
Anyone that wants the docs PM me and I'll send them through when I'm at home.
Yeah I just changed from Gulf Western to GTX and my timing hot start chain rattles are back, ahh well back to supercheap!!Originally Posted by Toobs
Are you saying you are going back to GW?
Have you guys seen these?
Does this mean if you take a car into Toyota thats on the 5W-20 list for a service that has 150,000kms on the engine, they will still use 5W-20?
Daily: Toyota '05 Rav4 Sport
