Results 46 to 59 of 59
Thread: The real oils
  1. #46
    Junior Member Grease Monkey Cruiser97_80's Avatar
    Tasmania
    Default Re: The real oils
    d-master
    you could put your theory to the test. Go to kmart buy your self some nice cheap home brand oil (change this regularly). Take your car out to a track day, I would suggest transporting it there (just in case). Then count the number of flat out laps you could do before engine damage occurs.
    Nah just joking.
    Synthetic oils are a good idea for turbocharged cars because of the temperatures the oil can withstand. The oil that lubricates the turbo gets extremely hot as you could imagine.
    1990 ST185 GT4 3SGTE
    1991 ST184 SX 3SGTE
    1991 SW20 GT 3SGTE
    1998 ST215 GTT 3SGTE
    2008 VDJ200 Sahara
  2. #47
    Quote Originally Posted by SYC02T
    I found that Nulon have bought out their own range of oils.
    It is apparently Fuchs with some badge engineering. I am running it at the moment.
    I think that if I can afford it, then I will try Royal Purple next.
  3. #48
    Built! not bought Grease Monkey SYC02T's Avatar
    Yeah, Had my eye on the Royal Purple. Looks good but bloody expensive.
    Hope the saying goes 'you get what you pay for' goes here or is it just for the name
  4. #49
    Dude, Royal Purple is a 100% PAO type full synthetic. I am waiting on some scans of independant testing to put to rest a few other points in this thread to
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  5. #50
    Quote Originally Posted by go_the_datt
    and speaking of oils and slightly OT. on the weekend my sister went to a school fundraising auction. she bided on and won a $250 car serves. she just got a phone call from mechanic and has to pay an extra $50 because in the service they include 3 liters of oil and they had to put in 5l. WTF?? $50 for 2 extra liters of oil and what car only holds 3L?? haha feel like going down there with her and going WTF.
    i did tell her though to expect a bill for 50-100, cause their gypsey bastards and cant give anything for nothing.
    most 4 bangers are 3.5 ltrs, that includes filling the filter aswell,
    the 1g is only just over 4.....
    i use castrol, magnatec semi synth, i only use it coz i get it for fweeeee!
    and its changed after all race meets,...
    ive changed the oil 4 times in 3 months......and changed the filter once,
  6. #51
    Normally Aspirated Domestic Engineer RT104GT's Avatar
    Went down the local auto parts supply shop today to get me some oil.
    I found that Nulon have bought out their own range of oils. Now I know they make some realy great additives, but has anyone used or got any real data/info on this stuff. Because as the others say 'oils ain oils'.
    I was also looking at the royal purple range, these look the goods, bit on the pricey side, but if it does the job exceptionaly well then you get what you pay for!!
    Mind you the synthetic Nulon oil was about $44/5L
    What comments do you guys/girls have or suggestions.
    Cheers τΏτ
    N??? oil was put in a Lycoming 0320 aircraft engine and had a forced landing due to engine failure as two exhaust valves clogged up in the guides and stuck open. The sellers denied liability and lucky I am still alive to tell the tale.
    The engineer had to hammer the valves stuck in the guide with a sledge hammer.
    To get them out and they are sodium filled worth $750 each.
    This story is probably irrelevent. so disregard.
    The engine was a horizontally opposed 320 cubic inch 200 hp, air cooled aircraft engine so again is not relevant.
    I have no idea what car oil is like but I use Penzoil or Quaker 3 state in my 3L turbo 280Z on LPG and at 5000 km the oil is like sewing machine oil clean like honey..
    PS. I am told you dont put synthetic oil in brand new only real old engines???
    1968 RT40S Corona 1600S series II (restore in progress)
    1973 RT104-MQFG 012604 Corona GT JDM (Owned since 1976 242000 km)
    1989 ST185-BLMVZ-0007199 Celica GT4 JDM (unmolested classic 95000 km)
    2012 ZN-6 86GT (shed find 5000 km in 6 years)
  7. #52
    I've been using the Castrol Edge 10w-60 in the 3S. Found being the 60 an advantage as on track days it seems to retain some more oil pressure when its hot.
    But being a 6.5 L sump it costs an arm and a leg to do an oil change which I try to do after each track day.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
  8. #53
    Quote Originally Posted by d-master
    My brother got this new Castrol Edge Sport 15w40 for his 2L turbo Sigma, cost him about $50. It makes 140hp at the wheels and is still running sane boost levels (11psi)
    Was it worth it? And on the back of the container it says "Increased fuel efficiency"
    I've always believed that change the oil more often is better than buying something more expensive.
    ahahahaha in my old xc falcon sundowner panelvan i used to use the FRANKLINS $8 = 4ltrs of oil,
    but the motor had 350,000 on it and burnt more oil then fuel!.....the rings were fine, but valve guides were ROOTED...and used to blow a massive cloud of smoke for about
    10-15seconds everytime you start it......LMAO!
    the old MINI OWNERS saying...."can you fill up the oil and check the fuel"
    blake
  9. #54
    Quote Originally Posted by RT104GT
    no you use synthetic oil in NEW motors, as its thin and lubricates better,
    you use just the usual mineral oil in older engines as its usually thicker and does burn as much....and doest leak through every tiny seal....
    saying that aswell, you can get THICK viscosity full synthetic oil....but it cost an arm and a leg compared to the thiner FULL synth....
    blake
  10. #55
    Since this thread is in view again I thought you guys might like to know that Gulf Western have released a new ester based synthetic with their usual top notch pricing.
    Sougi S6000 - Numbah wan doorifuto oil!
    http://www.gulfwestern.com.au/category.asp?CategoryID=8
  11. #56
    JZA80 Convert Backyard Mechanic
    Any older PF.com members on here might remember a guy called rhspecr who apparently did a lot of chemical analysis on oils for McLaren a few years back. Apparently he wrote a lot of info on the Mobil 1 site about their oils as well. He hasn't been around PF for a while, but before he disappeared he posted up excerpts from a 15k word study he performed on a number of common oils. The results of which were an interesting read.
    The thread that he posted it in has since been deleted on PF.com but I have saved the docs he posted at home and can send em through to anyone who is interested in them. There's a lot of chemical analysis information in them so a lot of it was over my head, but still some useful stuff in there.
    Anyone that wants the docs PM me and I'll send them through when I'm at home.
  12. #57
    Quote Originally Posted by Toobs
    Yeah I just changed from Gulf Western to GTX and my timing hot start chain rattles are back, ahh well back to supercheap!!
  13. #58
    Are you saying you are going back to GW?
  14. #59
    Have you guys seen these?
    Does this mean if you take a car into Toyota thats on the 5W-20 list for a service that has 150,000kms on the engine, they will still use 5W-20?
  1. stupid 3tgte question(sorry is a real noob question)
    By lilcrash in forum Tech and Conversions
    Last Post: 20-03-2006, 07:13 AM
  2. oils an't oils what to use in a 3s gte?????
    By sirbabblealot in forum Tech and Conversions
    Last Post: 14-02-2006, 10:26 PM
