Results 16 to 30 of 74
Thread: B&M Shifter Fitment - A340
    Default Re: B&M Shifter Fitment - A340
    I am trying to use a camry shifter.. maybe this my prob? as if you pull on a camry shifter, it pushes the cable.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    looking at pictures of b&m shifters they are same as a camry in that a pull down on the shifter pushes the cable.
    Forum Sponsor Conversion King
    Quote Originally Posted by TurboRA28
    show pics,
    you will probly have to mount it off the back of the shifter that way when you pull the shifter it will pull the cable, get me?
    fark ok.. might have to cut up the base of the camry shifter and turn it all around. that means this cable i had made is wayyyy too long now as thought it would come out the front and loop back. maybe it is easier to make new brackets on the gearbox so the arm points up.
    First pic shows the stick in L
    This pic shows the stick in P
    There's your problem The lever you have from MV is designed for the reverse, as with the B&M ratchet, when you push the lever, it pushes the cable etc.
    The lever supplied by MV may not have the correct arm length to match the ratio of your camry shifter either, so it may over/under select gears.
    This is all sounding like bad news for you
    Just go the B&M shifter, the Coaster will love some ratchet shifting action
    yep, shes back the front.
    either go for some fully hektic B&M goodness or mod the camry setup so the shifter comes out the back.
    you could go the other way around and have the arm facing up also,
    but before you proceed any further than you have, be 100% sure that the factory style shifter you are using has a gear selection of 1-1-1-1-1.5 as park-reverse must be 1.5x the movement of the other shifts if you know what i mean. ie your shifts should be 10mm-10mm-10mm-10mm-15mm from L to Park,
    they dont need to be that exact number but the ratio must be correct or the gears wont always select properly or you may not be able to get it into Park.
    Linden
    Hey Linden, ok I confirmed that the Camry shifter I have is the correct ratio, or close...
    My measurements gave me -
    10mm-10mm-10mm-10mm-18mm? Not quite 15mm but maybe that is a slight inaccuracy in my measurements.
    So I am thinking my best option may be to use the original selector arm on the gearbox that points upwards, with the cable coming out the front of the camry shifter.
    So I need to do two things, make a bracket to hold the cable onto the gearbox and then work out where to drill the pivot hole on the arm.
    damn, and here I was thinking I was just going to be able to buy the mv autos bracket kit, get a shifter, and plug all the shit in..
    It appears not.
    Facebook | LinkedIn
    Quote Originally Posted by stradlater
    It appears not.
    buy a B&M rachet shifter, buy the MV autos arm, and it will.
    8.3 et PB 169 MPH PB
    i'll probably be selling the mv bracket kit if anyone needs it as i don't think it'll suit my purpose now.
    Quote Originally Posted by 1JZ.747
    Nope, Why do you think i started this thread originally?
    Even Mike said it may not be correct and i would have to double check it.
    So in short, No it won't.
    but once you have the correct length it all goes together easy enough.
    Linden
    so I'll need to get the correct length hey.
    Facebook | LinkedIn
  1. T50 shifter rebuild questions
    By HRV-00S in forum Tech and Conversions
    Last Post: 18-06-2007, 03:46 PM
  2. W58 short shifter question
    Last Post: 22-05-2007, 07:38 PM
  3. AE101 Silvertop + blacktop 5speed?
    By Pure-SX in forum Tech and Conversions
    Last Post: 01-03-2007, 01:51 PM
