Results 31 to 45 of 58
Thread: Car turns off for no reason
    Least it doesnt snore Backyard Mechanic Gary's Avatar
    Default Re: Car turns off for no reason
    does it happen reasonably often? or just the two times youve mentioned?
    my x83 did it with its old engine, sometimes itd cut out and turn off just as though i turned it off with the key - no hesitation or roughness, just out like a light. other times itd do it fast enough for the engine to try and recover, jerking its way along till i gave it a bootful out of frustration
    turned out to be the kickdown cable, i hooked it up to the wrong hoopajoob on the throttle linkage thinking it was cruise... i realised this conveniently after i replaced the engine with a 1J. not overly likely thats your drama, but give it a feel anyway see if its alright
    JZX83
    UCF11
    Nov 2007
    Only those two times. The engine turned off but the dash was still Illuminated.
    Quote Originally Posted by Z2TT
    Would a rich condition be the problem?, I know 1g's run very rich stock, and my AFM spring must have loosened a lot from all the heat, causing the engine to run extra rich, especially when the BOV vents.
    I may adjust the AFM spring one tick tighter.
    DUDE..FFS..
    give up on the little bit rich thing or this or that..
    if it is CUTTING OUT, then something is STOPPING WORKING...
    if it is losing a bit of power, or spluttering or something, then maybe you have mixture problems...
    but if it is just cutting out, then either your fuel or spark is NOT FUCKING THERE.... got it? heh heh
    AFM click will just fuck up something else...
    something is fucked and causing car to cut out..
    LOLocoptor
    Nov 2007
    Yeah I get what you are trying to say, I just cant find the cause of it.
    Could it be due to fouled spark plugs? Or if that was the case would the engine be spluttering all the time?
    if the engine is losing power and spluttering or carrying on, then it could be fouled plugs, poor spark power, wrong mixture, intake leaks..
    BUT, you say it cuts out.. so that means you are COMPLETELY losing spark, or fuel..... not partially.. not a little bit blocked, not fouled, not rich or lean (well.. could be totally lean as in no fuel)... you are LOSING something completely.. so it cuts out.
    then again, if for some reason all your injectors are suddenly sticking open and hosing fuel in, then you can get rich cut... or if they are suddenly staying closed, you could get lean cut...
    but, something is completely going away.. nto partially...
    Nov 2007
    Correct.
    I wonder why it happens so rarely though, Like others have said it may be something getting knocked loose when going over a bump.
    Tallahassee, FL USofA
    Did you notice this when it happened or afterwards? Are there surges/sputters/coughs tiny bit or does it shut off just like it's been switched at the key? Tach jump?
  8. #38
    do you know exactly which part or which wire caused the problem in your Z20?
    LOL.
    Dude, plenty of people have told you the likely problem, why are you trying to think up random other (un)likely issues? Instead of going out and looking for/ruling out what's been suggested?
    You seem to be disinclined to listen and accept info from people because it differs from what you expected to hear?
    Toymods Club Member
  9. #39
    Don't Trust Me I'm A Backyard Mechanic Jabtronic's Avatar
    Gold Coast, QLD
    It's only happened twice so far right?
    I wouldn't worry about it
  10. #40
    Junior Member Grease Monkey nilprospects's Avatar
    Sep 2008
    i'm wondering if theres a problem with the knock sensor? (if it has one)
  11. #41
    Quote Originally Posted by nilprospects
    what would a knock sensor do?
    richen the mix, retard timing... NOT have a sudden cut out of the engine.
    It has to be either fuel stopping (injectors stopping for some reason or fuel pump stopping) or ignition stopping - electrical issue
  12. #42
    i think it might be the aerial...
    or maybe the material of the back seats perhaps?
    have you vacuumed it out recently?
  13. #43
    Car needs more sex with tailpipe.
  14. #44
    Sep 2008
    from what everyone has said and your answers to there suggestions im willing to bet that the problem is electrical.
    if its cutting out completley no spluttering or loss of power etc then obviously (as oldcarollas stated 500 times) something is obviously loosing power.
    and as the lights etc are staying on then it must be either
    -power/earth to the computer
    -power/earth to the fuel pump
    or a loose connection somewhere (to the computer or a sensor etc)
    i had a similar problem a couple of years ago in one of my cars and it turned out to be a wire to the fuel pump. it would drive along fine then all of a sudden the engine would just shut down, no spluttering or anything. i found the dodgy wire. replaced it and ran a new earth wire to the fuel pump and never had a problem again.
  15. #45
    Convictania
    I have a similar problem in that when I try and do backflips in my suzuki swift it seems to turn off for no reason - and catch on fire.
  1. Replies: 2
    Last Post: 10-08-2007, 07:58 PM
  2. less turns lock to lock in te71
    By cooter in forum Tech and Conversions
    Last Post: 05-04-2006, 11:55 AM
  3. Reputation Reason
    By JustCallMeOrlando in forum Toymods Car Club Membership and Feedback
    Last Post: 01-02-2006, 06:17 PM
