Results 16 to 18 of 18
Thread: Supra auto to manual swap info?
    Toyota fanatic Grease Monkey Gttwinturbomk3's Avatar
    Jun 2007
    Dunedin
    Default Re: Supra auto to manual swap info?
    When replacing flywheel bolts with new ones do you have to use loctite on them?
    If you need to use loctite on them what other bolts need it used as well in the conversion?
    I wasnt going to use it but maybe its worth it.
    Also would there be any real benefits in me lightning the flywheel up on it?
    I was thinking if that was done that there would be noticeable low down torque lost on the 1ggte? Would any other modifications have to be made to suit the new lightened flywheel or simply put it back in and use it? Thanks
    James
    You can use loctite if you want but it's not essential.
    Don't lighten your flywheel, either buy an aftermarket low-mass flywheel or use the stocker and leave it alone. Removing material from a cast flywheel is dangerous and can lead to unpleasant outcomes.
    Jun 2007
    Dunedin
    Ok, I will re-surface the face and just leave it alone and put it back in then
    Thanks mate.
  1. AE92 sec auto, conversion to manual 20v, questions
    By Mickp in forum Tech and Conversions
    Last Post: 23-06-2008, 09:18 AM
  2. Auto 4AGE Loom, Manual 4AGE, PROBLEM!
    By prizedbnx in forum Tech and Conversions
    Last Post: 18-04-2008, 04:03 PM
  3. auto ecu runing manual car
    By sam-131 in forum Tech and Conversions
    Last Post: 06-05-2006, 12:56 AM
  4. 1GEU > MTEU + Auto > Manual in GA61 swap
    By KwS in forum Tech and Conversions
    Last Post: 06-12-2005, 01:36 PM
