Results 1 to 6 of 6
Thread: AE92 sec auto, conversion to manual 20v, questions
    Apr 2007
    Default AE92 sec auto, conversion to manual 20v, questions
    Hi there, Just picked up a 20v manual ae92 hatch with a stuffed body. and an ae92 seca with a good body but its auto.
    Was hoping someone could tell me whether I can switch the whole kit from the hatch into the seca including all the manual gear.
    I searched and couldn't find anything specific on this.
    Any advice would be much appreciated
    Thanks in Advance - Mick
    Default Re: AE92 sec auto, conversion to manual 20v, questions
    yes you can
    Apr 2007
    Thanks for that, thats one thing down.
    Do you know if I have to change the fuel tank/pump/lines becasue the 20v is injected and the seca is carbied?
    it's best to swap the tank and lines over. You'll have to run the power wires for the pump from the drivers kick panel to the fuel pump under the rear seat.
    Also easier to swap the dash looms over too as then you get all the circuit opening relay stuff and the fuel pump circuit etc.
    Jun 2006
    do the Hatch and Seca have the same fuel tank?
    If not, does the standard 4afe use the same EFI pump? IE same pressure and GPH?
    4afe fuel pump runs the 20V just fine. I haven't personally put a seca tank into a hatch, but I have put a hatch tank into a sedan. From memory the seca tank will fit the hatch.
  1. JDM 86 Auto to Manual questions
    By driftymcgee in forum Tech and Conversions
    Last Post: 07-08-2006, 05:46 PM
  2. Replies: 2
    Last Post: 04-08-2006, 06:25 PM
  3. GZ20 auto to maunal conversion
    By Big rob in forum Tech and Conversions
    Last Post: 03-03-2006, 06:15 PM
