You'll probably find a cross-member swap isn't required, you'll just need the mounts. As far as we can tell we haven't seen any differences in them.
I'd be purchasing an entire clutch/flywheel/gearbox setup from someone with an MA61, surely someone must have one.
You may get lucky with the loom, I've never checked to be honest. That said, with a setup as simple as the MTEU, you're unlikely to come across too many difficulties.
Don't forget you'll need a manual tailshaft too, as it's longer.
As for worrying about it, it's a definite that it will go in, so with a bit of perseverence, it will happen.
) would be to get another engine, a 1GGTE manual front cut would give you almost everything you need to bolt it into the GA61.
