Results 1 to 15 of 20
Thread: Suggestions -Charcoal Canister 1ggte RA28
    Built not Bought Grease Monkey Rosie's Avatar
    Default Suggestions -Charcoal Canister 1ggte RA28
    Need suggestions on charcoal canister for my 28 1ggte,
    ideas - from wreckers Which vehicle?
    Size - would like smallest possible;
    Location - where have u mounted it.
    Outlets - from top of inlet right? the right angled tube?
    Must be engineerable / legal.
    Anything else i've missed
    Cheers Rosie.
    1977 RA28 1GGTE - never ending project
    Cough 'yaris' Cough - don't ask.
    Default Re: Suggestions -Charcoal Canister 1ggte RA28
    Quote Originally Posted by Rosie
    Cheers Rosie.
    Rosie, the charcoal cannister from a 1G-GTE Soarer/Supra front cut is about as small as they come. I mounted mine nearly exactly where the the RA28's original cannister was mounted.
    cheers Chuck
    MS51Crown Coupe,
    Got an engine package not a 1/2 cut so no canister -
    As for original location it's been a long build and wouldn't have the faintest, was thinking in front of wiper motor behind the strut.
    TX3 or maybe mazda familia have a tiny canister... Skylines im told are pretty small...
    Fords and/or Holdens are very close to the same size as stock ones if you just need something to get you by...
    Let me know if you find something small thats common, as i want a smaller more compact one
    Jase
    JZA023
    Rosie, the original location is down on the LH chassis rail in the engine bay, pretty close to the brake line hole in the inner guard. (plenty of room down there even with a 1G-GTE in the bay) MX83 Cressida use the same smallish cannister.
    cheers Chuck.
    MS51Crown Coupe,
    Charades also have a nice small canister
    The old One Backyard Mechanic
    The original RA28 canister works a treat. It fits in its original position (just have a look at a RAxx) perfectly with the 1GGTEU.
    Cheers Craig
    suzuki swift/holden barina is the same cannister as the GA70 ones nice and small and squarish
    i second the charade EFI canister - the outlet to the engine has a 1-way valve in it (so engine has to suck fumes out of it and you don't need a VSV to isolate it) and being rectilinear in shape, it's easy to make bracketry up for it.
    TAS
    Hmm... would a one-way valve like in the brake booster line work?
    EDIT: this is also for 1G - running aftermarket ecu and forward-facing plenum, but still have stock manifold lying around if the appropriate valve is situated at that end rather than the 1G's stock cansiter's end.
    stefan: if the canister came out of the engine donor car (or an EFI car fort hat matter) then no need to add any extra valves
    TAS
    Ahh, toyota = built in valve? The canisters I have to choose from are MA61 and RA65, both pretty big.
    I bolted my ke30 one inside the front guard on a modified bracket. Run two vaccum hoses through the guard then popped them through the side of the engine bay behind the drivers strut tower. One to the return line and one to the throttle body.
    Love the idea of putting it in the cavity behind the guard - awesome.
    Visiting pickies tomorrow -
    Thanks Fellas.
    Rosie.
    Junior Member Backyard Mechanic Hash_ra23's Avatar
    Quote Originally Posted by ddeane
    Cheers Craig
    pics for proof?
    1977 RA23 Celica -> 1ggte conversion [SOLD]
    MA70 Supra 1JZ 5speed [SOLD]
    Current: IS200 1JZ VVTI 6 speed
  1. ra28 1ggte engineering legals - brakes
    By Rosie in forum Tech and Conversions
    Last Post: 31-07-2011, 07:44 PM
  2. walbro fittings and surge tank setup on a 1Ggte / Ra28
    By thomasbl in forum Tech and Conversions
    Last Post: 12-06-2007, 11:02 AM
  3. Issues - 1GGTE into RA28 (yes another 1!)
    By TA-022 in forum Tech and Conversions
    Last Post: 18-09-2006, 03:20 PM
