epic fail every poster in this thread so far
correct response
climb in the window and HTFU
a mate had a problem with his corolla, it wouldnt unlock, we got a pair of plyers onto the lock and lifted it, got the door open and took the door trim off,
the problem was a centeral locking motor that was seized, could something like this be the problem?
correct response
i pulled three hundred rocks from the land to build my house
i walked quiet through the forest like a tiny quiet forest mouse
the oceans will rise
please stand by the shore
could you not paint it orange with a rising sun on the roof (and japanese 01 on the side) to make an oriental General Li.
and if you have seen the latest Dukes of Hazard Movie you would know that Bo and Luke "converted" to Japanese... Just need some home made Saki in the back seat.... and a Samurai sword and you're done...
Oh and weld up the other door
Yeeee Haaaaa ... (or would it be Banzai?)
The other side is a mirror image, so check it out for the mechanism & lever/s that do it. Practice. With the window down that stuff is all readily available with an length appropriate screwdriver or coat hanger.
If it's not like those newer latches that really grab & encircle the door pillar striker plate, Ralph Nader stuff, then getting at the hinges with the removal of the fender is easy with some cars fenders/wings, something to avoid on others.
Shelve 'em..... ie: use the back door.
Simon.
1991 Toyota Cressida (JZX83).
Taking off the front quarter should give access to the door hinges?Originally Posted by takai
opening the back door of a coupe might be a bit difficult.Originally Posted by Slim
+1 for the dukes of hazard idea.
Owner of the Big Red Whale
Originally Posted by Stomps
Don't use reality to destroy my joke.Originally Posted by dfunkt
Simon.
so far ive just given it 1/2 a can of wd40, will let that soak thru and hopefully give it a crack tomoz.....
cant wait to get into it and rip out all the vaccuum central locking shit thats in there!
Maybe that is the problem, the door is simply locked.
have someone on the key and someone on the interior lock at the same time, and work it a bit. some door latches wont operate if the lock is "halfway" between lock and unlock...
all of the toyotas ive taken front quarters off needed the door open to undo the bolt thats at the bottom of the a pillarOriginally Posted by Bananaman
maybe take off all the bolts except for that one and gently lift the panel enuff to get in there i suppose, but it wont be fun.
I think every car i've worked on is the same in regards to taking the guard off, you need to have the door open, but in alot of cases on most cars, you can access the hinge bolts via the wheel arch behind the guard as said in my last post.Originally Posted by rob
MY 87 ADM AW11 mr2. Now with previa sc14! http://www.toymods.net/forums/showthread.php?t=39380
Blake, according to the good Toyota book, you could have a "probrem" with the vacuum control valve. However if the car has not been run for a while, maybe you should turn the old 4M over. AW shit,you have no engine in the bay at the moment. Find a vacuum source on a car close by, and run a long length of vac hose to one of the numerous vacuum fittings in the coupe.
Hope this helps cheers Chuck.
MS51Crown Coupe,
still got a running 4m in there atm...its not coming out for a while now.... none of the vaccuum stuff works......maybe i should trac a line back...see if it will help?
