Page 1 of 4 123 ... LastLast
Results 1 to 15 of 57
Thread: doors jammed shut, can get it open!!! CUT THE DOOR AND STILL NO LUCK!
    Default doors jammed shut, can get it open!!! CUT THE DOOR AND STILL NO LUCK!
    hey giys,
    the drivers door is jammed shut on my crown coupe, has been pretty much since i bought it
    now, ive have a good go at jaming hooks/wire down the door to try and hook/push bits to get the damn thing open.....with no luck,
    i cant get the door trim off as the it gets sealed in once the door is closed,
    and atm my options are looking like, fucking the door trim or cutting a hole in the door skin, NEITHER I WANT TO DO!
    can anyone recomend anyone, anything to get the thing open?
    cheers, Blake
    Jun 2006
    Default Re: doors jammed shut, cant get it open!!! recomend anyone/anything?
    it is not just sagging hinges is it? I once had a 260c Nissan coupe as a paddock basher and it got to the stage that the door would not open without me laying the shoulder into it each time I wanted to exit...
    try someone in the car using the inside handle, and someone outside doing the same whilst lifting the door also..
    If all else fails, try taking the front guard off and removing both hinges (if possible) and you may be able to get the door far enough away from the body to remove the inner trim and trigger the latch.... (obviously being very careful of paint work etc ... and having someone to hold the door if it releases).
    good luck.
    Convictania
    Yeah do the above, but have the person on the inside jam the handle open and kick the shit out of it from the inside, while you pull.
    the problem being boys is that doors/trims for a crown coupe are not redily available from the local grocery store
    the hinges were fine, door wasnt sagged at all from memory,
    Convictania
    Sucks about the trim being stuck in the door then..
    maybe slice then end off witha stanley knife and pull the trim off and get the edge fixed later if ALL else fails..
    Junior Member Grease Monkey DRIFTAMK3's Avatar
    Jul 2008
    If it comes down to it and you do destoy the trim y dont you get some sheet ally and make a new one and recover them...
    Have you taken taken the Bailey channel off when trying this? Gives you a heap more room to play, and to see what's going on too. Could get a spray nozzle for WD40/Inox/whatever and blast the crap out of the linkages with penetrant (if things are just stuck that is, not broken)
    never had this problem so im just throwing it out there
    take rear trim off and then you can get to the latch, slot the back of the screws, screw them out door opens?
    Hiro, yeah bailey trim is shifted outa the way, got plenty of room to see and hook things, just not enuf for a hand or hammer
    Rob,......i'll look into that idea......i'll have to see if theres enuf room behind the rear trims,
    Perth WA
    My experiences with opening sticky/stuck doors:
    1: lubricate the exterior door handle, to make sure it returns to it's resting position - some door handles won't activate the relaese unless in their resting position.
    2: follow the rods - exterior door handle, interior door handle, locking snib, ..., you'll usually find the problems here - broken tangs, brittle plastic clips, bent rods,...
    3: radiator screwdrivers - are fantastic for pushing tangs etal from outside the door (through the window slot) that rods normally do.
    4: try every combination of exterior and interior door handle, and exterior and interior lock - some designers are truely fucked in the head and opening a door outside common conventions requires you to think outside the square.
    Junior Member Domestic Engineer Alex's Avatar
    Aug 2006
    vic
    I dont know how the hinges are setup on the crowns, but if it's possible to get to the hinge bolts via wheelarch or behind the front guard, loosen those and see if taking pressure off the hinged end will allow the door catch to release.
    Another possibility is the door may have too much outward (opening) pressure too especially if the door jam rubbers are new and thick, so try pushing/nudging the door closed with your knee whilst pulling on the handle.
    Quote Originally Posted by TooF View Post
    ha feburary!!! i im aiming for skids oclock in december.
    MY 87 ADM AW11 mr2. Now with previa sc14! http://www.toymods.net/forums/showthread.php?t=39380
    fill the bastard with wd40 spray it everywhere and let it soak.
    would breakign the glass give you more room? at least it is easyer to replace...
    One method i have used in the past is to remove the hinge bolts and get the door open (suicide style) just enough to remove the weather sealing on the body and get a fine hacksaw blade at the clasp. Hacksaw through that and its home free baby.
    ninja edit
    so you can actually access the inside of the door?
    hmmm boot it?
    south australia
    is there some interior trim that can be unscrewed, ie like around the latch area and the door puller handle? there are usually some nice sized holes behind these and you might be able to reach in through one of these holes to get a grasp of a rod or something and yank.
