Page 3 of 6 FirstFirst 12345 ... LastLast
Results 31 to 45 of 79
Thread: Toyota BEANs, Multiplex etc
    May 2010
    Moscow
    Default Re: Toyota BEANs, Multiplex etc
    so in fact, you only need to run Nissan speedo/tacho via CAN? That's quite easy
    You can actually find some info on the web. Like I did when installing 4gr-fse into Mazda RX-8. It also uses CAN for instrument cluster. It even uses CAN RPM data to power on/off electronic power steering.
    I think I can fabricate appropriate converter
    Nov 2011
    I want to put a tacho rpm pulse from an ls1 ecu into a module which then connects to nissan can system which then gets tacho working in dash which is can
    Once that's working I need to do air con and water temp gauge working in dash to
    But the tacho is main thing for now
    May 2010
    Moscow
    As I said, I see nothing impossible. A minimum test setup would be the proper data logs and a target instrument cluster.
    There's some solution to your problem other than running a CAN converter. You may just leave factory ECU and fool it so it outputs the valid information to its digital lines.
    May 2010
    Moscow
    upd: problem solved. DID & MID fields were needed to properly calculate the CRC. Each packet needed a different initialization pattern but the same CRC polynom, and the initialization data was exactly the DID & MID ))
    Jun 2014
    Khabarovsk
    George, how did you calculated CRC? No one polynom gives me correct results...
    May 2010
    Moscow
    Maybe start with introducing yourself, show us more details on your research? Do you plan to share it? What chassis do you work with?
    Jun 2014
    Khabarovsk
    Yes, sure.
    I try to understand how BEAN protocol works. I want to connect in-house built devices to this bus.
    Using info from book you bought and shared on this site, I understood BEAN frame format (thank you for sharing book!) and built sniffer for BEAN.
    As I found, most messages on BEAN network are sent repeatedly (2014-07-14 CodeSort.txt). First byte is count of messages got, second - CRC repeated from end of the frame, and frame itself.
    Meaning of messages is unknown for me... I plan to make simple BEAN sender and send messages to bus and see what devices will response to them.
    I also drawn scheme of BEAN sender/receiver. I drawn it from photo of conditioner's PCB. It is very similar to scheme from original book. But I have no luck when tried to make it work in Proteus... So I think I'll make simple form of transceiver using one transistor :-) Let there be noise :-)
  8. #38
    May 2010
    Moscow
    Sorry can't explain too much details right now. PM me a bit later. Are you familiar with Matlab? Got any logic analyzer?
  9. #39
    Feb 2008
    MD
    Hi George,
    Can you explain how you reverse engineered the CRC poly? I want to hack the mpx on a Celica ecu, but I'm rather new to Bean. It appears that the CRC8 always has a 1 as its first digit, leaving 128 other combinations of which 1111111 and 0000000 are not possible, so that leaves us with 126?
    Is there a program I can use or build to figure out which of the 126 poly combos it is? If not, I don't mind figuring it out on my own but would need a little nudge in the right direction if you are feeling generous. I have an Oscope, but not Matlab ... do I need to buy it?
    I've been programming a uC as an add on device and want to communicate with my gauge cluster.
    My failed attempts are posted below.
    DID D2 - 11010010
    MID 26 - 00100110
    DATA1 00 - 00000000
    DATA2 80 - 10000000
    CRC B1 - 10110001
    EOM 7E - 01111110
    11010010001001100000000010000000 10110001
    D2260080 10110001
    DID + MID + DATA1 + DATA2 = P(x) = x8+ x7+ x5+ x4+ x0 OR P(x) = x7+ x5+ x4+ x0
    DID + DATA1 + DATA2 = P(x) = x8+ x7+ x5+ x4+ x0 OR P(x) = x7+ x5+ x4+ x0
    (MID + DATA1 + DATA2) (DID + DATA1 + DATA2) = P(x) = x8+ x7+ x5+ x4+ x0 OR P(x) =
    x7+ x5+ x4+ x0
    DID D2 - 11010010
    MID C8 - 11001000
    DATA1 02 - 00000010
    CRC E9 - 11101001
    EOM 7E - 01111110
    110100101100100000000010 11101001
    D2C802 11101001
    DID + MID + DATA1 = P(x) = x8+ x7+ x6+ x5+ x3+ x0 OR P(x) = x7+ x6+ x5+ x3+ x0
    DID + DATA1 = P(x) = x8+ x7+ x6+ x5+ x3+ x0 OR P(x) = x7+ x6+ x5+ x3+ x0
    (MID + DATA1) (DID + DATA1) = P(x) = x8+ x7+ x6+ x5+ x3+ x0 OR P(x) = x7+ x6+ x5+
    x3+ x0
    DID D2
    MID 2C
    DATA1 01
    CRC B5 - 10110101
    EOM 7E
    D22c01 10110101
    DID + MID + DATA1 = P(x) = x8+ x7+ x5+ x4+ x2+ x0 OR P(x) = x7+ x5+ x4+ x2+ x0
    DID + DATA1 = P(x) = x8+ x7+ x5+ x4+ x2+ x0 OR P(x) = x7+ x5+ x4+ x2+ x0
    (MID + DATA1) (DID + DATA1) = P(x) = x8+ x7+ x5+ x4+ x2+ x0 OR P(x) = x7+ x5+ x4+
    x2+ x0
    Quote Originally Posted by George View Post
  10. #40
    Nov 2011
  11. #41
    May 2010
    Moscow
    gte
    you should concatenate all the fields rather than summing them. Ant then run a variety of 8-bit polynomials against them
    Also note that bit stuffing is applied on informational fields
    Try to check out this challenge
    http://cryptopals.com/
    It will improve your programming skills in performing activities like bus decoding, etc
    dumbass
    Apparently gte already has one
  12. #42
    Feb 2008
    MD
    That's unfortunately not an option. I'm pretty sure I could build a crude version of that for under $100 though ... maybe that's my only option?
    A uC that would detect bits and print them to the screen as hex through firmware conversion would be sufficient I think. If I have the hex, I can then try to reverse engineer it I believe.
    Quote Originally Posted by dumbass View Post
  13. #43
    Feb 2008
    MD
    Hi George,
    Thank you for the hint. I will be working on this today thanks to your direction .
    Do you have a few complete example fields I can concatenate and test against? I saw the text document you've linked earlier with 5 fields in it, but from your hint it sounds like I would need all 10 fields.
    gte
    dumbass
  14. #44
    Feb 2008
    MD
    Looks like I'll definitely need a few examples of an entire set of data with all 10 fields as guessing is not working. I may have to build my own sniffer before hand as well.
    Am I close George?
    ______________
    Edited
    SOF (1bit) 1 (1) (guess)
    PRI (4bits) 3 (0001) (guess)
    ML (4bits) 49 (01001001) (calculated)
    DID (8bits) 62 (01100010)
    MID (8bits) D2 (11010010)
    DATA1 (8bits) 00 (00000000)
    DATA2 (8bits) A0 (10100000)
    DATA3 (8bits) 08 (00001000)
    CRC (8bits) 0A (00001010)
    EOM (8bits) 7E (01111110)
    RSP (2bits) 2 (10) (guess)
    EOF (6bits) F (00111) (guess)
    73 total bits
    00001010
    DID to EOM = 62D200A0080A7E (poly is P(x) = x8+ x3+ x1)
    SOF to EOF = 134962d200a0080a7e2f (poly is P(x) = x8+ x3+ x1)
    ML (4bits) 41 (01000001) (calculated)
    DID (8bits) 98 (10011000)
    MID (8bits) CC (11001100)
    DATA1 (8bits) 02 (00000010)
    DATA2 (8bits) A8 (10101000)
    CRC (8bits) 35 (00110101)
    65 total bits
    00110101
    DID to EOM = 98CC02A8357E (poly is P(x) = x8+ x5+ x4+ x2+ x0 )
    SOF to EOF = 134198cc02a8357e2f (poly is P(x) = x8+ x5+ x4+ x2+ x0 )
  15. #45
    May 2010
    Moscow
    I'll post my matlab script's output as an example for you
    PRI|ML 64
    DID 98
    MID CC
    DATA1 02
    DATA2 A8
    CRC 35
    check crc: 35
    CRC OK
    EOM 7E
    p/s one more file
    ------Original packets count:5 --------
    PRI|ML 64
    DID FE
    MID 40
    DATA1 00
    DATA2 00
    CRC 3E
    check crc: 3E
    CRC OK
    EOM 7E
    PRI|ML 64
    DID D2
    MID 26
    DATA1 00
    DATA2 00
    CRC B1
    check crc: B1
    CRC OK
    EOM 7E
    PRI|ML 53
    DID D2
    MID C8
    DATA1 00
    CRC E9
    check crc: E9
    CRC OK
    EOM 7E
    PRI|ML 63
    DID D2
    MID 2C
    DATA1 00
    CRC B5
    check crc: B5
    CRC OK
    EOM 7E
    PRI|ML 64
    DID 98
    MID CC
    DATA1 02
    DATA2 A7
    CRC D4
    check crc: D4
    CRC OK
    EOM 7E
  1. Toyota R Engine History
  2. Toyota Distributor and DLI Ignition Systems - explanation and guide
    Last Post: 14-11-2010, 01:42 AM
  3. TCC Dyno Day - 23/09/2006
    By Starfire in forum South Australian Events
    Last Post: 25-09-2006, 08:16 AM
  4. Replies: 0
    Last Post: 20-07-2006, 12:18 PM
