Page 2 of 6 FirstFirst 1234 ... LastLast
Results 16 to 30 of 79
Thread: Toyota BEANs, Multiplex etc
    Default Re: Toyota BEANs, Multiplex etc
    Quote Originally Posted by cambelt1
    Maybe so , if i get a chance i will plug it into my manual VVti engine and see if it starts ,
    Just found the date is 3/2001 .
    I,ll pull the cover off it but do you have the mpx 1 and 2 pinouts handy
    I will check if they go anywhere inside
    Dave
    Looking at the ECU pins, 4th plug from the left (28 pin plug).
    Bottom lower left pins are MPX1 and MPX2 (in that order left -> right).
    If that doesn't make sense let me know and I'll mark it on a pic
    vic
    Those pins are indeed linked together by a link on the pc board , resistance between the pins is .25 ohms so id say thats enough of a short . a single track then goes off to im not sure where because of the multi layer board .
    Now do i want to check my 6 Speed ECU Hmm i,ll have to get the double earth strap on for that rare one.
    I have both looms if we need to compare anything . What pinouts have you got Will and can you send them to me .
    Dave
    MPX1 and MPX2 are linked by a track on all the ECUs I've opened up.
    The presence of MPX doesn't indicate an immobiliser - is that what you were looking for?
    Mos.
    vic
    Yes im looking for the imobiliser in this ecu but we were just curious on the mpx pins,
    Whats the pins i need to look at .
    This JZS 161 Engine ECU the mpx pins are linked by normal wire link about a inch in from
    the plug pins . I spent a while probing the input resisters but didnt find where it went to .
    Dave
    RXCK, CODE, TXCT - they're listed on the diagram wilbo posted - they should be on the 2 row plug (just like the VVTi 1UZ).
    This JZS 161 Engine ECU the mpx pins are linked by normal wire link about a inch in from the plug pins.
    Sorry, I should've said "they're connected internally" rather than "linked by a track". On the IS200 cluster they're a track, but I can't remember what they were on the IS200 ECU or the 1UZ ECU.
    Yeah, there's not a lot of point tracing them. I spent some time tracing the immobiliser traces on the 1UZ ECU but they disappear into different ICs...
    Mos.
    May 2010
    Moscow
    Didn't anyone discover more about BEAN bus? Sorry for bumping seemingly dead thread.
    May 2010
    Moscow
    p/s I found some bery helpful info (packet format etc etc) in US patent # US2002003781
    May 2010
    Moscow
    p/p/s complete description costs $24 here Body Electronics Area Network (BEAN)
    I did some research though and would share the results if anyone's interested
    Triptek Enhanced Backyard Mechanic triptek's Avatar
    I'v been messing around with this the last week wiring up a jzs161 2jzgte vvti in to my jzx100. Mainly to get the aircon to function properly, which i have managed to do by wiring in the jzs161 AC ecu. I also dummy wired in the jzs161 dash cluster just to make sure the multiplex was working. I'v realized that you don't have to wire both mpx1 and mpx2 up. I just have mpx2 from engine ecu going to AC ecu, and it functions correctly including A/C idle up. When i chucked the dash cluster in, that also worked correctly IE: water temp/auto position dash lights/oil pressure etc. It seems the multiplex will still work in a engine conversion with most of the donor vehicles body ecu's missing
    I plan on wiring in the body ecu tomorrow, so i can try and get the auto power/normal function to work
    1994 GZX90 Mark II 1GZ-FE V12
    May 2010
    Moscow
    triptek, do you have an opportunity to run a couple tests on the hardware you have? That would require a PC with LPT port, or a serial port, or (best option) an oscilliscope.
    I'm now trying to isolate signals for a/c idle up, and pwr/snow on/off to build some emulator to use in engine conversions. I have already figured out the data structure used. If I receive some help here, I would share the info I have.
    May 2010
    Moscow
    Bought a book containing the SAE paper mentioned above. Thought it would be nice sharing it.
    https://drive.google.com/folderview?...VE&usp=sharing
    May 2010
    Moscow
    Here's what I could decode from a Celsior (1uz-fe vvti) ECU with nothing conected to it
    Can anyone help me out with the CRC field? I have very little idea how to calculate it. None of the 126 possible CRC8 polynoms fit
    Attached Files Attached Files
    Nov 2011
    im trying to find some time to buy a can bus data capture device and try to make something for when fitting ls1 ls2 ls3 motors into late model patrols and other can based vehicles
    once u decifer the can signals in the patrol then maybe one day program something to convert the gm can signal to work on a patrol canbus
    it prob take me 5 years to build
    May 2010
    Moscow
    CAN is easier as it's more popular
    I've got a CAN sniffer handy
    it ain't too easy to build the converter you describe as long as you have both vehicles complete for testing
    I'm now more focused on the MPX stuff
    Nov 2011
    Dakota digital make units that read obd2 and spits out a tacho pulse and a speedo pulse
    I'm hoping to make something that does the opposite
    I spent hours trying to get tacho parking on a 350z with an ls1 with no luck
    So I need to figure how to get rom into Nissan canbus
  1. Toyota R Engine History
  2. Toyota Distributor and DLI Ignition Systems - explanation and guide
    Last Post: 14-11-2010, 01:42 AM
  3. TCC Dyno Day - 23/09/2006
    By Starfire in forum South Australian Events
    Last Post: 25-09-2006, 08:16 AM
  4. Replies: 0
    Last Post: 20-07-2006, 12:18 PM
