Results 46 to 60 of 81
Thread: Wanted: 20V 4age expert!! QLD
  1. #46
    Default Re: Wanted: 20V 4age expert!! QLD
    word of caution: given the dodgy wiring you already have, is not likely that one visit will cure all (if anything). I'd suggest we look at trying to separate the engine loom (or what's left of it) from the spagetti/tape loom that currently infests the car.
    Then form that, rebuild the engine loom leaving you to do the fun bit (fixing up the lighting.dash, etc).
  2. #47
    Jun 2006
    We shall soon find out what you think of the wiring i suppose
  3. #48
    so how did you all go?
    sorry i couldnt attend, ive been driving from south Brisbane to the sunhsine coast all weekend... how lame.
  4. #49
    Jun 2006
    Chuckster came around and rewired a few dodgy things, then we removed the air flow meter pipe and pushed in the afm flap to engage the fuel pumps and its started on all 4. Chuckster then did a check on the AFM and found that i might be dodgy so i need another AFM to check if its what needs to be replaced
  5. #50
    so its running/idling?
    nice work
  6. #51
    not idling, but running a bit better.
    AFM was open circuit between 5Vref and earth (should be a fixed resistance) and the wiper and earth was also open circuit (should vary).
    weirdest thing. we could get engine to run sensibly (e.g. sound like a 4AGE) with finger shoved down AFM to open up the vane. Otherwise, it sounded like it was trying to run on 4 cyls. Was thinking about it on the way home - and came to conclusion that when normally running it opens up a lot less during starting and idling.
    Also, fuse panel wiring fixed up so inj power and fuel pump didn't have battery power but are correctly switched. Very dodgy.
  7. #52
    Jun 2006
    I tried to get a Air Flow Meter from the Local Wreckers but they didnt have one, Does anyone have one left over from a conversion or even one i could lend for 5 minutes to see if its at Fault??
  8. #53
    Hide Yo Kids Hide Yo Wife Carport Converter hamgatan's Avatar
    im surprised noones asked Bill Sherwood for help yet... (Forum Name - Billzilla)
    if anyone knows 4AGE's AND Clubbie's its him... (and hes in QLD which is a bonus for ya..)
    JZZ20 1988 Soarer GT Twin Turbo
    1JZ-GTE + R154 + LSD | Black Knight Still being Assembled
  9. #54
    have you contacted Anthony at Kaizen yet? he has alot of parts, and is pretty decent with the ole 4ag
  10. #55
    Jun 2006
    I was hoping just to get a lend, as we still arent 100 percent that is the problem
  11. #56
    T'ville, QLD
    i have a AFM dunno how good it is though
    i could check the resistance if somone will provide some rough values for me to compare against
    2T out 4A in....
  12. #57
    Jun 2006
    Where r u located dude
  13. #58
    There are some 3sge/3sgte AFMs that are a near match to the 20V one. Plug is the same but measuring range is a little out. And the3s one has bigger cross sectional area.
  14. #59
    Jun 2006
    I can get a second hand one, but we are still not 100 percent sure that its the AFM if anyone around the sunshine coast has one that they can spare for 10 minutes that would be great
  15. #60
    Apr 2008
    Hey guys, I have had a brief look at this car about 3 months ago. I don't have much 20v experience, except for ones fitted with Adaptronics, so me knowledge of the standard ECU is limited.
    Strangely, I did pick up a change in voltage when testing the MAF, I specifically remember it.
    Also if I am correct, and im just assuming here, the MAF triggers the fuel pump when it is open any amount, which works well.
    It was only a brief look but does that sound right about the fuel pump?
  1. 4AGE 100kw into AE92 (where 4AFC used to live)
    By Grega in forum Engine & Driveline Conversions
    Last Post: 24-07-2008, 05:53 PM
  2. 4AGE -> AE86 Conversion: Accessories question
    Last Post: 17-06-2008, 08:53 PM
  3. 4AGE 86KW TVIS V 100KW 4AGE + Shocks
    By GeeEss in forum Tech and Conversions
    Last Post: 17-01-2007, 08:51 PM
