Results 31 to 45 of 46
Thread: 2JZ overboost problem.....fixed :D
    Default Re: 2JZ overboost problem.....fixed :D
    so its running ttc then...
    dont listen to the nay sayers, but we should aknowledge that they did help people like us know which path would lead to failure and without guys like 2jzr31 i probably wou8ld have quit long ago.
    look foward to the sequential,
    Not just a regular Backyard Mechanic ProjectSleeper's Avatar
    Good write up.. I was lazy and just fitted a 2.5" restrictor
    User Conversion King
    NWA
    this was my restrictor i was previously using
    horrible!
    hello
    My restrictor is actually a replacement section of the exhaust.
    It's flanged both ends and easily swapped..
    Basically a section about 60cm long between the Cat and 1st Muffler. Standard piece is 3" straight through, but the 'restrictor' is a 2.5" section of pipe that is flared up to match the 3" flanges at both ends.. works a treat..
    i got mine laser cut...
    NWA
    hahaha.... why they bothered 'seperating' the manifolds makes no sense.
    hello
  8. #38
    NWA
    sequential works...
    put your foot down from low rpm..... 13psi by 2400rpm then at 4000rpm it dips very briefly to 8-9psi and then bang, straight back up to 14-15psi
    hello
  9. #39
    fucking awesome!
    so did you need to make up a controller circuit or can the ecu control it by himself?
  10. #40
    NWA
    thats with no other mods.
    essentially the 2nd turbo has no prespool and comes online once the EGCV opens.
    you could experience the sequential operation yourself (as i have it now) if you want to disconnect the prespool actuator and go for a drive.
    hello
  11. #41
    oh no prespool.....
    how long will you run it like that?
  12. #42
    vic
    Well time will tell i guess , is there any info regarding spinning turbos up to quickly .
    Maybe you could pre open the EGCV then have it fully open .
    My guess is the surge from 1 to both coming online is much greater now?
    Dave
  13. #43
    ^ yea thats what i am planning to do.
    now brett has tested NO prespool for me (i was too scared and was going to do it right before i pulled the turbos) and seems to be ok.
  14. #44
    NWA
    maybe the rear turbo life will be halved from 15yrs to 7 years now.
    hello
  15. #45
    NWA
    bit of an update.
    this is how i am running it now with the boost controller.
    i get about 14psi on the 1st stage and 17-19psi on the second stage.
    transistion drops very briefly to 8psi. its pretty unnoticable IMHO.
    bear in mind this is without the a prespool valve
    here is a schematic of how it is setup. note that the boost controller reference line doesnt actually come from the manifold, it comes from the front compressor housing. essentially the same thing though.
    hello
  1. Toymods Uploaded photos problem
    By JBs in forum Toymods Car Club Membership and Feedback
    Last Post: 26-11-2007, 03:18 AM
  2. CT26 Overboost Problem (56K warning)
    By Matty P in forum Tech and Conversions
    Last Post: 14-11-2007, 08:13 AM
  3. Replies: 6
    Last Post: 27-10-2007, 07:45 PM
