Page 26 of 33 FirstFirst ... 162425262728 ... LastLast
Results 376 to 390 of 481
Thread: Celica Brake Upgrade
  1. #376
    T'ville, QLD
    Default Re: Celica Brake Upgrade
    yes it appears that way doesnt it.....
    today pushed on the struts (still in the celica) to turn them got them full lock and heard a clunk, now i cannot turn them back even with the steering wheel, what did i do?!? and how can i fix this?
    2T out 4A in....
  2. #377
    New Zealand
    Have you checked it wasn't the steering lock clicking in? Its quite often the little things that get overlooked.
    Callum
  3. #378
    I like Stuff Backyard Mechanic mikie's Avatar
    does any one have a list of toyota models that came with 4 pot calipers, may be a worthy research project.
    cheers mike
  4. #379
    just cause i like you guys http://users.on.net/~ndean/RA60_RNP_INTO_RA28.doc
    Stepho too is where i got the idea but from chats with him he never finished it to the point of driving?
    All measurements of toe and bump seem within 1mm.
    Basically i had 1mm toe in one side and 1mm toe out the other when finally checked properly. Basically with a 'proper' wheel alignment im confident the angles are near perfect.
    Rememberint this is using ra60 x-member / ra28 steer knuckels and then the hilux/pug combo.
    Black Betty >HERE!<
    (\__/)
  5. #380
    south australia
    Quote Originally Posted by TA-022
    fixed
    character nonsense
    but cheers
  6. #381
    bah my bad
    Black Betty >HERE!<
    (\__/)
  7. #382
    New Zealand
    Well the MS65 hubs definitely fit TT132 struts with no impact on offset, I measured it to be within 1mm. Now I just have to sort out the brakes, have SW20 MR2 fronts to play with.
    Callum
  8. #383
    hey fellas, here is what i have spent for the conversion so far with receipst:
    XT130 struts L & R (with two piston) $90
    - wheel bearings AKIT (2 x outter) $16
    - wheel bearings BKIT (2 x inner) $18
    - hub bearing seal (for L & R) $10
    Hilux calipers LN106 L & R (the one with fins) $150
    - genuine brake pad L & R DB1149 $80
    - caliper rebuild kit L & R $40
    Peugot disc brake rotors vented 604 L & R (pick up monday) $140
    - machine down to 266mm (price on monday)
    - enlarge holes 1.5mm (price on monday)
    Im just having problems removing the piston out of the hilux caliper for rebuild. I got 2 out using a flat head screw driver and levering it out, what is the best way in this procedure? or do i leave that to the pros?
    fonzy
    deepdishfactory
  9. #384
    T'ville, QLD
    Quote Originally Posted by w810sc
    my price list looks similar except
    rt132 struts - $70 (pair)
    ln130 calipers - $70(pair)
    pug rotors $65 ea
    machining and re-drilling $60
    2T out 4A in....
  10. #385
    measured rt132 / 133 and xt130 hubs today.
    xt130 and rt133 are the same from disc mounting face to hub face.
    rt132 is 3-4mm wider
    *CONFIRMED!*
    Black Betty >HERE!<
    (\__/)
  11. #386
    Sweet. Off to get 4 RT132 hubs then.
    As for my rough price list, i was talking about this with Gavatron in the car:
    XT130/RT132 complete struts $90
    Peugot 604 Discs $150
    Machining $30
    LN106 calipers $140
    Rebuild kit $22
    Bendix Ultimates $84
    Datsun 240K BMC $80
    Coilover spring perches $100pr
    Coilover springs $70ea
    Strut inserts $80
    Cutting and welding $tba
  12. #387
    The rt132 hubs are 3-4 mm wider diameter?? So they must sit past the rotor very slightly.
    So does the holes still need to be filed on the rotor? Im assuming yes.
  13. #388
    yes, but its better to get them redrilled 90degrees offset from the old holes
  14. #389
    Hoppers Crossing
    yes...holes need to be enlarged ever so slightly to accomodate.
    FWIW my setup uses the TA22 spring (albeit a king spring lowered) with plenty suspension travel no issues.
    my convo details are here : http://forums.toymods.org.au/index.p...t=0#msg_231301
  15. #390
    Nay, not wider in diameter. Wider in offset. Ill find a picture a bit later, but the XT130 hub face lines up with the base of the ribs on the caliper, not the top of the ribs. It appears that the RT132 hub face will line up with the top of the ribs, or close to at least.
    By The Witzl in forum FAQ
  2. xA6x, xZ1x, xX7x + others FRONT AND REAR Brake Upgrade
    By CrUZida in forum Tech and Conversions
    Last Post: 24-07-2018, 11:43 PM
  3. AE86 Brake Upgrade Options
    Last Post: 07-04-2006, 02:29 PM
  4. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
