Don't worry, everyone else is confused also. As far as I know, the cold start injector shouldn't be part of this problem. It's the same as a choke on a carburettor. What your experiencing is the fuel pressure gushing out. When you said you aligned the holes in a bolt I assume you mean it was on a banjo connection so it should not matter where the hole goes. As far as I remember, the cold start injector operates off one of the temp sensors independantly of the rest of the system. The only issue with these is that they might dribble and give poor fuel economy which is not your problem because your engine dies when it is reved. If you apply 12v to it it should open and squit out fuel but if you do this fix the wires otherwise you and the car will burnt with a flame thrower. Are you sure the timing is not hugely out? Are you looking at the correct marks on the pulley or flywheel. Can you remove a spark plug, stick a screw driver into it and determine top dead centre approximately? Then compare it with the pulley mark. Possibly the key has sheared and the pulley moved slightly or someone left the key out. I had a car once that idled great was undriveable because the timing was way way out.
i'm hoping i just haven't put one of the fuel injectors back in properly as it cranks over, runs a little and dies, but i thought if injectors weren't in it wouldn't turn over at all. Ideas?
