Results 1 to 13 of 13
Thread: 4age air box temp sensor?
    Junior Member Backyard Mechanic pete05's Avatar
    penrith nsw
    Default 4age air box temp sensor?
    Ok so i bought a ae92 4age corolla the other week and it has been fitted with the typical sports exhaust (sounds like crap) and the typical pod filter with dodgey pipe work, my question is seem as the air box is missing what effect does it have that its also missing the intake temp sensor?
    Junior Member Grease Monkey progkamol's Avatar
    Default Re: 4age air box temp sensor?
    how dodgey is the pipe work??? I have seen a few cars with dodgey pipe work and they have a chrome coated plastic pipe approx 20cm long connecting from throttle body to pod filter (or even a Nike sock) and quite a few of them actually drill a hole into the pipe and install the sensor (eventhough some are not even seal properly) ...
    Signed
    M4C
    penrith nsw
    the pipe work i can fix, its more the fact that the sensor is missing and i dont know what effect the missing sensor has on the ecu
    My smallport was missing the air temp sensor (bigports have the sensor in the plenum from memory)
    I found one and wired it up, i just zip tied it near the inlet of the pod filter.
    benefits were:
    better fuel economy
    much better power,
    engine felt much more "crisp"
    all due to the engine running too rich with no sensor.
    get one!
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    penrith nsw
    Quote Originally Posted by roadsailing
    benefits were:
    better fuel economy
    much better power,
    get one!
    makes sense, my small port runs like a bucket of crap compaired to my big port.
    will see if i can get a new one
    get ready for the obligatory toyota parts heart attack, i priced one at 90 bucks or so a few years back, after the guy tried to convince me there was no such thing
    www.vicdrift.com
    penrith nsw
    yeah, i can get trade so i hope its not to bad
    AB
    Its in the AFM or MAF if you prefer on the "bigports"
    Quote Originally Posted by merc-blue
    Cheap tools take all the fun out of working on a car.
    My Rebuild and Conversion.... '81 Tercel 3A -> 4A-GE 20 Valve - ON HOLD.
    BAD ASS 1986 MR2 - Finally Moving forward.
    It's in the plenum on map equipped bigports.
    A trip to pick'n'payless shouldfind you the air temp sensor. I've found a few there in my various searches.
    Aug 2006
    success 6164
    on some big port's like mine its in the air box instead of the inlet manifold..found a few differences between big port's when i swapped my motor in my ae82.
    http://www.ae82ownersclub.com/forum.php
    powered by 4agze ae82 goodness.
    I've been going through hassles getting an air-temp sensor for my AE82 at the moment, it seems MAP bluetop bigports (aka 3-rib) have the air temp sensor in the intake plenum, whilst MAP red/blacktop bigports (aka 7-rib) have it in the airbox. Unfortunately, when mine was converted from 3-rib to 7-rib, the airbox and intake piping weren't swapped over. So I've got a 7-rib plenum with 3-rib airbox, and thus no provision at all to mount a temp sensor.
    Being fixed at the moment, but the car has been driven for probably years without the sensor with little ill effects (probably idling too high, and the ECU constantly throws a code, but apart from that it's fine)
    penrith nsw
    tried there several times with nothing so far.
    i wonder if any other toyota runs the same sensor ?
    toyota wanted $88 for a new one, just trying to decide if its worth the dollars for any improvement i might gain.
    Also planning on doing a coolant temp sensor and an o2 sensor as well.
    Dont know why but i stopped getting emails to notify of replies to this thread. strange.
  1. Placement of Intake Air Temp Sensor
    By Drifty Midship in forum Tech and Conversions
    Last Post: 19-11-2007, 02:11 PM
  2. Thread size on a stock 1ggte water temp sensor?
    Last Post: 15-11-2007, 10:33 PM
