Results 16 to 30 of 42
Thread: Arse load of oil in my spark plug gallery - 7M
    drunken escapades Conversion King fatboy13's Avatar
    Default Re: Arse load of oil in my spark plug gallery - 7M
    gurney guns removes salt...
    then somehow you need to get rid of the excess water
    watching a bunch of supraforums members try to debate something technical is like watching a bunch of retards try to fuck a doorknob...
    then get new bolts for the cam covers, tightening those crappy assed screwdriver bolt crap things is impossible
    Domestic Godess, NOT Domestic Engineer clubagreenie's Avatar
    1. Don't forget to lube the threads on the new bolts with plenty of oil.
    2. Refer post one.
    Friends
    HP Guru Backyard Mechanic driftedmz20's Avatar
    Jan 2008
    just another bhg cressy 1st year Apprentice AndrewJZX100's Avatar
    Jun 2007
    ^^ thanks man, I'm gonna go out and suss it this arvo when it's not so damn cold.
    One thing though, draining the oil through the spark plug hole, wouldn't it just sit on the piston? I'm also getting nasty thoughts of the motor hydraulic-ing with liquid onto of the piston. Although it would be a damn sight easier than 'mopping' up all that oil with rags
    yes, DO NOT remove the plugs, it will lock
    rags, dergreaser and a hose,
    Jan 2008
    Quote Originally Posted by AndrewJZX100
    i let mine drain into the holes and turned it over with no plugs etc.......didnt hydraulic at all. Not saying that i recommend doing it but worked out for me and as my 7M is already on its last legs it didnt really bother me
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    Of course it won't hydraulic lock if you turn it over with no plugs...there won't be any compression! But it would just spray the oil all over the place.
    Jan 2008
    Quote Originally Posted by Gavatron
    LOL.............put rags over the holes and doesnt spray shit! then clean the excess oil out in between rocker covers etc with rag or whatever you please!
    Adelaide, SA
    Sounds like the awesomest, easiest way to do it. I'd just remove the 7M altogether.
    Jan 2008
    and then you would be a sheep and do what everyone else has done lol
    Quote Originally Posted by fatboy13
    Salt will soak up the excess water.
    Then you need to find someone who knows how to get rid of the salt
    Of course it scares me that you know how much of a load of oil your ass will take.
    Friends
    Nov 2007
    I pumped mine out with the pump you get in hand cleaner or shampoo bottle. Unscrew it from the bottle, stick the tube into the gallery, pump and catch it in a container or even squirt it back into the cam shaft area to drain back into the engine.
    Nov 2007
    Crambo method 2. You can fill chambers with water to float off oil then use straw to suck out water, if you don't like the taste, add cordial. Alternatively instead of water use Beer.
  1. argh!! 7M losing power under load
    By jimmmayyy in forum Tech and Conversions
    Last Post: 03-02-2008, 12:45 PM
  2. Spark plug stuck
    By smt_007 in forum Tech and Conversions
    Last Post: 18-01-2006, 08:58 AM
  3. know your spark plug codes
    Last Post: 05-01-2006, 11:44 PM
