Page 1 of 3 123 LastLast
Results 1 to 15 of 42
Thread: Arse load of oil in my spark plug gallery - 7M
    just another bhg cressy 1st year Apprentice AndrewJZX100's Avatar
    Jun 2007
    Default Arse load of oil in my spark plug gallery - 7M
    As the title says, I popped off the first spark lead on my 7M and found quite a nice amount of oil sitting in there (I couldn't actually see the spark plug ).
    Question is, how do I remove this as I have pretty much no tools or anything (basic socket set). I've got a bit of degreaser, but I'm not sure how that'll help me, there really is quite an amount of oil in there
    Any ideas/proven methods to rid myself of this problem (and hopefully get my nice smooth idle back?)
    cars are good 1st year Apprentice t-rex's Avatar
    Feb 2007
    Perth WA
    Default Re: Arse load of oil in my spark plug gallery - 7M
    i used a sponge, it took a while but im sure there are other better methods out there haha.
    no backyard Domestic Engineer japlish's Avatar
    a rag, screwdriver and patience
    Destroyer of 'Drop Forged' spanners
    Xistant
    Guest
    cloth, and lots of it!
    Feb 2007
    Perth WA
    oh and a syringe to get the last few bits.
    Altia ER34 GTT Domestic Engineer JetspeedCamry's Avatar
    Syringe w/ small hose on the end to suck it out, then tissues to dab/wipe it all up. Put tissues on the end of a screwdriver and get into all the corners. Once most is out, you can remove the plug and the clean the bottom a bit better. Then, fix the cause of the oil leak.
    Kind Regards,
    Kurt.
    1998 ER34 ニッサン スカイラインGT- T
    which was either a poor attempt at using your oil filler or cam cover leak
    do the cam cover gaskets
    then degreaser/carby cleaner and lots of water, let car run and get hot to clean evaproate any residue, then change the plugs
    (doing it this way has set a known soarer on fire.....apparently )
    vic
    A large syringe with a bit of hose attached is a handy item to have in your tool box! Also good for emptying oil catch cans, brake/clutch fluid reservoirs etc...
    Jun 2007
    Thanks gentlemen, I'll get out there with the rags n all that jazz and see how I go.
    Cam cover gaskets you say? It does leak and absolute arseload of oil (you should see underneath where it's parked ) so I might have to get around to doing that when I start work again.
    Omce again, cheers for the help + rep coming to you all
    piece of piss. gasket goo + socket wrench + gasket scraper, job done. (well, and some prepsol/degreaser and a rag)
    ^^^ almost as easy as installing brake pads backwards....
    Jun 2007
    ^ hahahah
    Hmm I might give the cam covers a shot. I'm more of a theory person though, tend to be fairly shit at actually working on cars, but I don't start work until the end of the month so I spose I've got enough time for it to sit through a few 'fuck this is crap I'll do it later' episodes
    hey, 7 out of 8 aint bad
    Salt will soak it up. Then you need to find someone who knows how to get rid of the salt.
    Friends
  1. argh!! 7M losing power under load
    By jimmmayyy in forum Tech and Conversions
    Last Post: 03-02-2008, 11:45 AM
  2. Spark plug stuck
    By smt_007 in forum Tech and Conversions
    Last Post: 18-01-2006, 07:58 AM
  3. know your spark plug codes
    Last Post: 05-01-2006, 10:44 PM
