then get new bolts for the cam covers, tightening those crappy assed screwdriver bolt crap things is impossible
gurney guns removes salt...
then somehow you need to get rid of the excess water![]()
1. Don't forget to lube the threads on the new bolts with plenty of oil.
2. Refer post one.
Friends
andrew - read this
http://www.toymods.net/forums/showth...842#post717842
^^ thanks man, I'm gonna go out and suss it this arvo when it's not so damn cold.
One thing though, draining the oil through the spark plug hole, wouldn't it just sit on the piston? I'm also getting nasty thoughts of the motor hydraulic-ing with liquid onto of the piston. Although it would be a damn sight easier than 'mopping' up all that oil with rags![]()
yes, DO NOT remove the plugs, it will lock
rags, dergreaser and a hose,
Originally Posted by AndrewJZX100
i let mine drain into the holes and turned it over with no plugs etc.......didnt hydraulic at all. Not saying that i recommend doing it but worked out for me and as my 7M is already on its last legs it didnt really bother me![]()
Of course it won't hydraulic lock if you turn it over with no plugs...there won't be any compression! But it would just spray the oil all over the place.
Originally Posted by Gavatron
LOL.............put rags over the holes and doesnt spray shit! then clean the excess oil out in between rocker covers etc with rag or whatever you please!
Sounds like the awesomest, easiest way to do it. I'd just remove the 7M altogether.
and then you would be a sheep and do what everyone else has done lol
Salt will soak up the excess water.Originally Posted by fatboy13
Then you need to find someone who knows how to get rid of the salt![]()
Of course it scares me that you know how much of a load of oil your ass will take.
Friends
I pumped mine out with the pump you get in hand cleaner or shampoo bottle. Unscrew it from the bottle, stick the tube into the gallery, pump and catch it in a container or even squirt it back into the cam shaft area to drain back into the engine.
Crambo method 2. You can fill chambers with water to float off oil then use straw to suck out water, if you don't like the taste, add cordial. Alternatively instead of water use Beer.
