Results 16 to 30 of 36
Thread: Point of AFM idle screw?
    Default Re: Point of AFM idle screw?
    I reset mine via the markings on the AFM, using the very scientific method of ruler and my finger. Will do it again with some verniers soon. The car is much happier idling now. I can't help but think it needs to be opened up a tad more.
    That said, I'd love to just piss it off completely and get the Microleb. Ahh, money.
    I thought about that too camrygt?. The thing I noticed though was that the AFM sending out a definite signal at idle, so it must be opening enough for the ECU to register something. Ah well, perhaps Toyota just weren't so confident in the ability of their ECU's to do it at the time
    Long Time Reader Backyard Mechanic willwal98's Avatar
    Do I get a prize for answering correctly? Eddi McGuire would have given me $100
    Nah...just playing.
    Yay! I'm an Automotive Encyclopaedia Hydra's Avatar
    Having played with that screw out of desperation, and the spring inside for the same reason, I can strongly advise that it's best to leave it alone from the start
    That said, you can lean out the mixtures across the board using that internal spring but i'd still say it's better to just get a jaycar DFA or something like that - far less chance for screwups. My AFM has no markings on it to indicate the correct height of that screw from what I have seen so i'm guessing whenever I set it up.
    If you look next to the idle screw, on a little flat section just below it, there is two numbers. They will be REALLY faint though, because they didn't stamp them that hard. I had to get some cleaner and give it a little scrub to be able to see them. Mine had 66, I set mine as close to 16.6mm and its behaved markedly better as a result.
    As for the DFA, I'm still dubious whether or not it can be used.
    I've put the DFA on my car, I could only test it at idle but it did make a difference to the mixture when I richened it up a bit (ouch my eyes!)
    (going out to look at AFM now!)
    Oh for sure. Mine appeared to work. I could happily play around with the mixtures at idle. As soon as I took the car for a drive though, anything approaching boost was emt with uber stutters.
    Hurry up and take it for a drive to check for me! If yours doesn't do it, then I have a problem with mine! Have you tried driving around on pass-through?
    Those uber stutters happened to me in a way, I think that was loose exhaust manifold - turbo nuts though.
    I just want a microleb too, far less 20 year old factory ecu headaches, way more cool stuff to play with.
    Nah, mine is directly related to DFA, as soon as it's removed, the car behaves perfectly.
    Have you driven the car with the DFA in just pass-through mode?
    I did a while ago, it was fine from memory.
    I would need to connect the bugger up again to test it again, which means pulling apart the dash... Did that too recently
    Riverina Chapter Automotive Encyclopaedia andyroo's Avatar
    Quote Originally Posted by JustCallMeFrank
    Where exactly is the idle screw, my idles horribly, drops to 8-7-6 hundred then sometimes stalls due to the misfire.
    Andy
    2009 Toyota Hilux SR V6 4x4
    2000 Toyota Avalon Grande -SOLD 2014
    1985 Toyota Celica XX 1G-GTE - SOLD 2014
    Quote Originally Posted by Hydra
    If you could check that'd be good. I'd love to be able to use mine, but she no worky atm
    Quote Originally Posted by andyroo
    Andy
    The one this thread about is on the AFM itself, and unless it's been removed, there should eb a cover over it.
    No really, please do, this boost cut is driving me nuts
    Andy
    That could be the ISCV could also be a cause of this and should probably be cleaned before playing with the AFM screw.
    Beige.... The new Black!!!
  1. Toyota Vane-type AFM
    Last Post: 20-02-2006, 12:15 PM
  2. Lumpy Idle and Lack of power
    By AJz in forum Tech and Conversions
    Last Post: 02-02-2006, 07:47 PM
  3. Low idle??
    By JetspeedCamry in forum Tech and Conversions
    Last Post: 09-01-2006, 12:22 PM
  4. Idle issues
    Last Post: 23-10-2005, 09:54 AM
  5. High 4AGE Cold Idle
    By toaster in forum Tech and Conversions
    Last Post: 23-10-2005, 03:08 AM
