Mate, your definite signal has a finite resolution... you can measure it to within very fine limits with a good multimeter, but if your ecu just has an 8 bit analogue input, then you will only have a total of 256 registered points between fully open and fully closed. This can be helped a bit with a non-linear varistor, but then that takes away from the fine throttle control you can acheive at the high RPM that these motors are designed for. SO.. at idle, a 1 bit change in the analogue input can be 20 or more percent change in overall reading, which will make a drastic difference, then at high RPM that same 1 bit change can be less than half a percent change... so your idle suffers from lack of resolution, hence the need to fine tune it, they get it to within a bit of where it needs to be, and then smacks it bang on that bit with the adjuster screw. With the newer cars came better microprocessors and higher resolution analogue inputs, and better non-linear varistors... so now there might be a 16 bit analogue input... doesnt sound like that much of a change, but it works out to be 16 thousand bits between fully closed and fully open... much finer resolution. think about the 256 colour screen your computer once had, and this difference it made going to a 16 bit screen with the 16odd thousand colours, and now you have your 32 bit screen with several million colours. That is why the early efis needed the manual adjustability that the new cars dont.Originally Posted by JustCallMeFrank
