Got any more info on that?Originally Posted by ed_jza80
something looks like it magically disappeared between the 2 pictures....and it wasn't the flywheel.
In all honesty i am just subscribing to this thread as i would like to manualise the 1uz before it goes in the celica....i was thinking of manualising the auto as one option.
Norbie!
www.norbie.net
You want one Norbs? I have a spare....i can set it up for Tremec or W series boxes. Comes with the super light 1.8kg flywheelStreet use is a bit iffy...doable but you need to have a very precise shift technique and bumper to bumper traffic would not be fun.
I'm just wondering if such a setup could be adapted to other Toyota engines which don't have a factory manual option.![]()
Norbie!
www.norbie.net
As in the GZ? and the answer is yes. In fact isn't the GZ crank PCD the same as the UZ? drop me a PM.
try scott at http://www.venomcobras.com/Originally Posted by xcedricx
im running a w57 behind my 1uz using a kit he put together for me consisting of skyline 5 puck ceramic clutch + dellows bellhousing (not the best looking but everything lines up) + 2800lb pressure plate and fly wheel. im pretty sure it came in under $2000. i have done over 15000kms so far with no dramas.
i dont even understand wtf that means...Originally Posted by barned01
norbs, call me if you like. and yes, justen has a spare triple with new plates for sale
mos - yes, going down to twins but with rally plates, not sintered plates - last longer, wear better
../delete/ban
tech moderator
I will pm you (clutch noob and i don't want to fill up this thread).
Toyospares also do a 1UZ to W58 kit, & can do mod' to the stock ECU to run a manual..
xUZ and 1gzfe share the same flywheel
Project: '82, GA61 XX
flex plate really....
So coming back to this, what sort of clutch is a good idea for something more performance orientated, and not going to destroy my bank account?
Along the lines of a single button type clutch? {not going all out just yet}
And are there any options for flywheel from any existing toyotas rather then going custom?
Turbo? NA?
NA to begin.
Turbo very soon after {when bugs/bank account have settled}
Then don't waste the money on the W58.
Go R154 minimum.
Thats what I was thinking, any idea on the flywheel/clutch options?
Or is it just simpler to get a clutch to suit the box, and get a custom flywheel?
