Page 3 of 3 FirstFirst 123
Results 31 to 45 of 45
Thread: 5sfe crank + 3sge = 5sge?
    Deal with the Frog Backyard Mechanic Cool1's Avatar
    Default Re: 5sfe crank + 3sge = 5sge?
    After readin this thread I dont know why i'm bothering with toyota rubbish! I mean I could just go buy a supa tough hondah and not have to worry about any mods!
    OGT-630 Grease Monkey rokusan's Avatar
    because hondas are ugly and their mothers dress them funny?
    SA63-3SGTE coupe driftpig
    Junior Member Domestic Engineer NeoNasty's Avatar
    HAHAHA lol
    HZJ75, RS41, JZZ30
    Quote Originally Posted by RWDboy
    3S-GTE's all have higher flowing pumps than the 3S-GE's and also the 5S-FE's.
    Not so sure on this one. The size of the gerotor in the Gen2 and Gen3 3SGTE is both the same. the Gen3 has a pulley with one less tooth though so it turns the pump faster flowing more oil. However apparently the late model 5S had a gerotor ~2mm deeper than the 3SGTE. If you buy one of those Toda hi flow pumps it is just a late model 5S pump with the smaller pulley.
    But the 5S pump housing is missing the belt guide stud thing! Not sure if that matters though?
    If you're talking about the alloy stud that gets screwed in next to the crank timing pulley I don't thinks it's too big an issue. The early Gen2 oil pump didn't have that at all. It's pretty funny when people rebuild an early gen 2 with a new oil pump and don't screw something into that hole, it goes right into the oil supply.
    Canada
    Quote Originally Posted by Joshstix
    This matches my experience.
  8. #38
    cruisin in a z30 Automotive Encyclopaedia -=DV=-'s Avatar
    Quote Originally Posted by Cool1
    why wait for vtec to kick in when ct26 kicks in so much earlier and harder and then TVIS yo!
  9. #39
    Exactly!! And YES!! I did forget to put a bolt into that extr hole and YES!! oil everywhere!!
  10. #40
    Quote Originally Posted by rolleraction
    5S crank drops straight into 3S block. You 'should' use a later model 5S crank as they have an 8 bolt flywheel that mates perfectly to 3SG f/wheel. The earlier models are 6 bolt and I understand not as strong either. Argo have a pattern for 5S rods as does eagle. (I;ve used both) Custom pistons have to be made. (Arias have a pattern for these (I have used them; as does CP pistons I believe (they advertise them, so...) Have crank balanced and nitrided. 'Revability' is not an issue, but up the oil pressure a bit. Rear seal was never an issue for me, the 3SGE one fitted/worked fine. Very torquey version of a 3S. 8000 rpm no problems all day. I spun big ends at 9000rpm, an oiling issue later rectified by upping preassure.
    Really that sounds like a bit of a beast, would be quite tight to run a nice 2.2 3sge, could you give a little run down of your engine build up if possible?
    Cheers in advance.
  11. #41
    here here ... quite interested if this is quite feasible and worth while.
    Black Betty >HERE!<
    (\__/)
  12. #42
    [QUOTE=rokusan]crank = 5s again a bit simple not having the same finish or knife edging as 3sgte and this one had a strange machining on it for balancing?
    This where the gear is pressed on for counterbalancer. You must have an earier crank? (Not as good) Was it 6 bolt 8 bolt at the flywheel end?
  13. #43
    its out of a st204? looks strange i'll get a pic, and i'll check that bolt hole out too....hmmm
  14. #44
    Sorry to dig up an old thread, but I see I didn't reply. My apologies. I am all exited over 3S's again after reading Glenn Booths thread on his beams' results....
    OK.looked at the phot finally...Yep that flat round section of the crank is where the ring gear is pressed onto. The ring gear (looks exctly like a mini ring gear on your flywheel for anyone who hasn't seen one) mesh's with a similar gear on a counter-balance shaft in some cars fitted with 5S series engines. The gear is cut or simply pressed off if you want to drop it into a 3S.
    From memory, 5S & 3S rods are the same length c2c, same pin size, but the big end on a 5S is about 52mm (could even be 54mm?) and I think a 3S is 48mm. I guess you could grind the 5S down to 48mm but unsure on strength etc. Offset grind for even more stroke could also be interesting with custom pistons with appropriate compression height etc........
    Steve
  15. #45
    you are right, the rods are the same length etc. the journals are smaller too like you said, i have come to the conclusion that the 3s is more than enough and the 5s turbo is probably a bit diehard....but id like to see some experimento....com'on you st204owners! bolt a hairdryer to that stocki!!
    interesting what you said about the ring gear, makes sense...
    it was an 8 bolt from memory, from a st204
  1. ST162 3SGE Swap (Photo Diary)
    Last Post: 07-10-2007, 10:38 AM
  2. Simple 3sge Mods
    By Lonewolf in forum Tech and Conversions
    Last Post: 18-02-2006, 01:47 PM
  3. 3sge - 3sgte CAS - interchangable?
    Last Post: 20-12-2005, 08:15 PM
