Page 10 of 12 FirstFirst ... 89101112 LastLast
Results 136 to 150 of 170
Thread: Wideband O2 sensors, a few questions.
  1. #136
    Default Re: Wideband O2 sensors, a few questions.
    Quote Originally Posted by chris davey View Post
    MWP: I take it you have the stock 0-1v setting for the o2 sensor on the microtech and that is why you say it is pretty useless? Can upgrade it to 0-5v for $100. I will be doing this with mine as I really like it for datalogging. Easier to read when all on the one graph I reckon.
    Yeah, its 0-1V at the moment on the Microtech, and it is useless as the readings are too inaccurate... as you would expect.
    Next time i have the dash apart ill pull the Microtech out of the car and take it apart.
    Odds are itll be quite easy to change a few components to have it reading 0-5v.
    The other problem is that the Microtech software is complete crap.
    Its logging functions are pretty useless with the max log length of 500 (IIRC) samples.
    With this you can only log short runs, not a complete drive, race, etc.
    The LogWorks3 software however, is very good and has a plugin API that allows sending the software extra data.
    When i get some free time, my aim is to write an app that will get the Microtech RS232 serial data, and send it to the LogWorks software.
  2. #137
    I am a drag racer so the 500 units is no issue for me
    Sorry what is this API? So you want to be able to run your laptop with no additional wires and fot the logworks software to pick up the data from the microtech rs232 cable. That would be pretty sweet. So short term you could just splice into the necessary wires for it to log rpm, map, tps and afr right?
    This lc1 seems too damn cheap. May as well get one of them instead of the jaycar as I am shit and building those things
    QUICKEST 1JZ'S IN OZ
  3. #138
    Well youll only get a couple of lines of log anyway.
    Yet another problem with Microtech's is the slow rate at which they report data.
    API = application programming interface.
    Plug both the LC1 and Microtech serial data lines into the Laptop.
    Run Logworks, then run my software which gets data from the Microtech and sends it to Logworks.
    Then youll have all the data (WB02, rpm, inj time, ign, etc) in Logworks which you can then record, graph, etc, etc.
    Splice to what?
    The LC1 doesnt have any aux inputs for doing this.
    This is what the Innovate DL-32 (and similar) is for.
    And the LC1 is proven, known to be accurate, etc, etc.
    With the Jaycar unit you wont really know its correct unless you can compare readings to another WB02.
  4. #139
    aaah so the logs on the innovate website are from this DL32 thingy then not the LC1. Just showing what the software can do. Makes more sense now
    So when are you releasing your software?
  5. #140
    Just ordered $270 delivered. Bargain
  6. #141
    what does that include Chris?
    JZA70|R / 12.45 @ 111 mph.
  7. #142
    They daisy-chain.
    You plug the LC1 serial out into the DL32 serial in, then the DL32 serial out to the laptop.
    Logworks will then read data from both.
    When it works... if it ever does
  8. #143
    wa
    Where????????
  9. #144
    Sounds like he is just getting the LC1 with no dash unit.
    I got mine from here http://www.kadespeedandmarine.com.au.
    Decent prices.
  10. #145
    +1 Vote for Kade speed and marine, they are good to deal with.
  11. #146
    eBay us. On phone now so will link later. Unit sesnor logworks and digital guage
  12. #147
    i paid $260 delivered for the LC-1 only in april '08 from a supraforums group buy but the killer was paying $259 delivered for the XD-16 gauge a month later from ebay. which was by far the cheapest at the time.
    I originally planned on not having a gauge and just using the LC-1 when tuning (when hooked up to the datalogit) but after i realised you cant turn the LC-1 off, it has to be always powered and hence using its life up I decided to make the most of it and get a gauge, which wasnt going to hurt keeping an eye on things.
  13. #148
    Chris be careful there are 2 gauges, average ones with slow response (DB) and the awesome ones with fast response and lots of flashing lights (XD-16)
  14. #149
    Texas,USA
    XD-16 aren't effected by ground offset either. More accurate faster responding.
    ae-86 (levin) footwork
    TE-71 w/1uzfe
    Autronics SM4
  15. #150
    Quote Originally Posted by JZA70 R View Post
    Wish i knew this before i bought mine
  1. 2JZ questions
    By kingd in forum Tech and Conversions
    Last Post: 20-03-2007, 11:31 PM
  2. sensors in exhausts
    By Adsport in forum Tech and Conversions
    Last Post: 06-03-2007, 10:09 PM
  3. Aftermarket Engine Management - Burning Questions
    By SilverGhost in forum Tech and Conversions
    Last Post: 01-07-2006, 06:30 AM
  4. Theory: Heat sensors in cylenders
    By Nim in forum Tech and Conversions
    Last Post: 30-06-2006, 05:18 PM
