Thanks, well here is my plan of action that I have chosen to work by. Let me know your thoughts.
1. Level the area out with sandpaper, sand down any rust and remove it with 400.
2. Sand area smooth and level with 400.
3. Apply rust treatment (Deoxidine or similar) to the rusted area of C Pillar to fix any residual rust and wash off as per instructions on product.
4. After rust has been treated, fill in gaps with primer and then sand with 400 to get the shape of the pillar nice. Use 800 to make it all smooth.
5. Apply one light coat of etch primer to area where metal is present that is going to receive paint.
6. Use highfill primer and spray across the area that needs to be leveled (area that contains low points), spraying horizontally
7. Sand down highfill primer with 800 to get it down level with the rest of the paint on the pillar
8. Basecoat 5 coats or so, spraying horizontally.
9. Sand basecoat if needed with 800.
10. Cleatcoat 4-5 coats.
11. Thinners on edge of clearcoat to blend to original work
12. After 5 days, sand clear with 1500 to remove any fish eyes and peaks.
13. Cutting Compound then polish.
Oh and here is the work I did on the rear 1/4 panel a few weeks ago, turned out good.
