Results 1 to 15 of 25
Thread: A simple O ring question...
    Junior Member Grease Monkey Darrien's Avatar
    Default A simple O ring question...
    Hi all.
    My AC in my JZ is leaking, my first thought is to change all those O rings.
    Are there different O rings for different purpose? or can I use any typical O rings on the aircon lines?
    thanks all
    Default Re: A simple O ring question...
    specific type of O rings to cope with the gas you are using are required.
    71 ta22 2tgeu,ke35 18rg, ke 35 3k auto,74 ta22 2tg,73 ta22 2t,80 ra40 18rgeu,92 kawasaki gtr1000,95 nj pajero, 2011 jeep patriot,2011 aricat jd495,1979 leyland motorhome (350chev),1995 Mitsubishi Delica
    Too many cars so little time
    thank you for clearing that up for me.
    Lick my hairy Backyard Mechanic Turdinator's Avatar
    The orings are green and the material is HNBR i believe. Anything else will leak.
    Domestic Godess, NOT Domestic Engineer clubagreenie's Avatar
    Color these days isn't a good indicator of material. Viton material used to come in green, brown, blue, yellow and black. All the same material but different hardness by color.
    I'd go via an air con specialist, I've only seen black ones come out of them and theat could be anything from neoprene to buna N to viton to HDPE
    Friends
    An air con place should also have a leak tester and be able to narrow down where the leak is coming from
    I am the sun
    I jus purchase a O rings set on ebay from UK.
    it is specific for aircon systems. Only one on ebay so far I searched.
    it is in black colour.
    This is the one I bought.
    http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN:IT&ih=002
    hope it is alright.
    they look like normal black Nitrile. they might work if not, you have spares for everything else
    usually O-rings are easier to buy by the piece from bearing shops...if they don't have the type you want they can usually order in... (i used to go through Hooper Bearings in mascot)
    ah, I should've ask here first before purchasing it.
    Went to super cheap and they only have an assorted packs with like 3 of eachs size total of 12
    they told me that is all I will ever find because that is the only way they ever sell it anywhere. I am a fool for taking their words.
    wa
    you can also buy the a/c o rings from toyota
    They only come in three sizes also so its not hard to get the right one
    I always thought the green ones were neoprene.
    Got a bunch from an air con guy - three different sizes, maybe 10 of each, on a cable tie (for free)
    It never hurts to change all the O-rings, especially if they've been disturbed at some stage.
    Mos.
    I did went to Toyota
    they dont stock them, and they dont even know for sure that there are specific O rings for air con lines. They told me to ask my mechanic LOL
    Quote Originally Posted by 2jzhilux
    well, I a hoping those O rings I got off ebay should do the trick. It is listed for used on aircon.
    Best to have it leak tested after anyways... it will cost a few bucks more than just a gassing (which you will need to do after you change the orings) but you can easily pinch an oring or have a pinhole in a line.
    EDIT: I agree with rollas, they look like standard Orings, or possibly high temp orings, certainly they dont look like specific AC ones. They specify that they work with oil and coolant, which isnt a good sign, as these fluids have different properties to AC gas/oil, and are likely to be able to destroy AC orings... seems some people will claim anything on e-ghey
  1. Quick & Simple Swaybar fitment Question
    By cam_ra40 in forum Tech and Conversions
    Last Post: 11-08-2007, 04:00 PM
  2. 2004 1zzfe corolla, real simple question
    Last Post: 04-12-2006, 09:20 PM
  3. 3S-GTE oil filter question
    By tangcla in forum Tech and Conversions
    Last Post: 31-08-2006, 03:55 PM
  4. Piston ring question (3sge)
    Last Post: 03-04-2006, 09:19 PM
  5. Another noob 18RG question
    By tricky in forum Tech and Conversions
    Last Post: 22-02-2006, 12:37 AM
