Results 1 to 7 of 7
Thread: 3S-GTE oil filter question
    Automotive Photographer Automotive Encyclopaedia tangcla's Avatar
    Default 3S-GTE oil filter question
    Can someone please help me with an oil filter question for the 3S-GTE please?
    Basically I need to order in a sandwich plate for an oil pressure sensor, and I am unsure which one I need.
    Please tell me which one is appropriate, from what I have gathered it should just be the center bolt pitch difference (the last one I think is not suitable for the 3S).
    O Ring 72mm/76mm, Center bolt Pitch M24xP1.5, Center Plug Bolt 1/8PTx3 M12xP1.25x1
    O Ring 72mm/76mm, Center bolt Pitch M26xP1.5, Center Plug Bolt 1/8PTx3 M12xP1.25x1
    O Ring 72mm/76mm, Center bolt Pitch 1-12UNF, Center Plug Bolt 1/8PTx3 M12xP1.25x1
    O ring 56mm/65mm, Center Bolt Pitch 3/4-16UNF, M20xP1.5 Center Plug Bolt 1/8PTx2 M12xP1.25x1
    GT4 Freak, and Conversion King Squid's Avatar
    Default Re: 3S-GTE oil filter question
    Well the 3s is entirely metric isn't it? so you can count the last 2 out...
    Is it? I don't know, that's why I'm asking you people because you're supposed to know more than I do!
    www.tangcla.com - photography
    Canon 5D Mark II x2 | 16-35mm f/2.8L | 24-70mm f/2.8L | 70-200mm f/2.8L IS
    100mm f/2.8L IS macro | 100-400mm f/4.5-5.6L IS | 580EX-II | 430EX-II x2 | PocketWizard TT1/TT5
    Add Lightness! Grease Monkey spectral's Avatar
    Its the last one:
    Thanks That's what I was told but I wanted to confirm it
    Quote Originally Posted by tangcla
    Ooh, so it was a trick question
    No, it wasn't a trick question. I just wanted to confirm that this was the case because I don't have a spare oil filter lying around, otherwise I could have measured it and found out what the O-ring diameter was myself
  1. remote oil filter question.
    By joecoolmk2 in forum Tech and Conversions
    Last Post: 02-04-2006, 11:39 PM
  2. 3S AW11 conversion: few detail
    By mullett in forum Tech and Conversions
    Last Post: 17-03-2006, 12:17 PM
  3. Oil Filter Interchangability
    By 3sgte in forum Tech and Conversions
    Last Post: 14-03-2006, 12:35 AM
