Results 1 to 10 of 10
Thread: Piston ring question (3sge)
    Junior Member Domestic Engineer urantia's Avatar
    Default Piston ring question (3sge)
    At the stage of assembling the engine back together. Noticed with the toyota ring set they come with no instructions. The no. 2 compression ring has a ridge on one side of the ring. What i want to know is which way this ridge is supposed to face?
    The rings have an "R" stamped on them, does this indicate the side that should face up?
    Thanx in advance.
    98 3rz-fe Hilux 4x4
    nothin' doin Grease Monkey
    Default Re: Piston ring question (3sge)
    normally, there is a letter, or a dot that should face upwards.
    the ridge usually faces upwards too.
    Quote Originally Posted by Rex_Kelway
    i am of no speech
    thanx steve,Thats what i thought, and there is white "R" stamped on the rings, but the ridge is on the other side, so i'm not which which to face up, the ridge, or the stamped "R"
    Will double check incase they are both on the same side.
    98 3rz-fe Hilux 4x4
    i'd go with facing the ridge up
    i am of no speech
    Ok Steve, will go with the ridge up, Thanx alot for your help i gave u pos rep.
    Cheers.
    98 3rz-fe Hilux 4x4
    Junior Member Backyard Mechanic 1jzracing's Avatar
    CAREFULL!!!!
    ask an engine builder the ridge is there to cause the ring to actually twist a little under load and SEAL! if its upsidedown it will do the oposite and leak or worst break possably damaging the bore.... i think iv seen the ridge if it is on the bore surface that your talking about goes to the bottom but double check this with an engine builder or workshop manual
    well pistons arn't back in the engine yet but have the rings on them with ridge up.
    Hmm i don't know why this is such a challenge! no documentation came with the ring set (stock toyota ring set)
    no information in the haynes manual. execpt to say there should be a mark indicating which way up the rings should face.
    There is a white "R" stamped on one side of the rings, and the ridge on the other side.
    This flamming ridge is holding me up, i'll ask an engine builder place tommorow then, otherwise i think i'm going to go with the "R"'s facing up.
    98 3rz-fe Hilux 4x4
    GO with the R mark up!
    no manufacturer puts marks on the bottom of rings, especially if they said the top would be marked, that fits with my memory for orientation of stepped rings too
    that would be what i would do without question, ive put together a dozen or more engines over the years, and most of them stay together fairly well :-) ... hehehe
    Rosewood
    http://ugbox.net/~lance/GT4/Technica...er%20block.pdf
    download and goto page 30.
    R goes UP
    R up it is!
    have had all matter of opinion of which way this ridge should go, alot of the older mechanics that i know say ridge up, but those R's are obviously there for a reason. So i'd say your right. pos rep.
    98 3rz-fe Hilux 4x4
    Last Post: 29-02-2016, 12:30 PM
  2. Another noob 18RG question
    By tricky in forum Tech and Conversions
    Last Post: 22-02-2006, 01:37 AM
  3. Simple 3sge Mods
    By Lonewolf in forum Tech and Conversions
    Last Post: 18-02-2006, 02:47 PM
