Page 2 of 5 FirstFirst 1234 ... LastLast
Results 16 to 30 of 62
Thread: WRX motor into a TA23
    Default Re: WRX motor into a TA23
    they are also arse to work on, try doing a set of plugs in 10 minutes,
    Montrose
    They have their good and bad points... I somehow doubt it'll fit for width, especially with the steering box in the way, but do by all means have a good measure. Subaru engines have a bit different method of mounting, which is both good and bad in your case. Still, its the only engine I've ever removed from a car without an engine crane, AND with the bonnet still on.
    (Now for some smartarse to pipe up and tell me about taking out their Camry motor with a hoist and forklift...)
    Actually MrShin, I removed the 3k from my brothers Corolla with 2 helpers and we didnt have to remove the bonnet (pulled it as far back as possible and tied it to a beam)... the motor came out with no troubles 2 people lifting, one making sure nothing hit anything and all connections were disconnected.
    So yeah, somebody had to be a smartarse... might as well have been me
    Montrose
    Well I didn't need to tie the bonnet back even
    Plus I bet the guy who helped you lift the engine out didn't have dreadlocks
    nope, not many military personnel do
    sir Grease Monkey
    tasmania
    go for it mate ,with a bit of nouse and a mate who is a boilermaker you can do anything . but they still sound like shit. cheers bigwad
    Tasmania
    I say have a crack. toyota owns %8.5 of suburu now anyway. the 23's have a bit more room then a 22.
    If you have the funds go for it, no conversions is cheap regardless of what you pay for the engine.
    Engine mounts are bugger all, bell housing can be made, first half of the scoobie housing, and the second half of the gearbox your using, weld togther and you away.
    1973 TA22
    Junior Member Domestic Engineer 1200det's Avatar
    Certainly would make for a beautiful sounding Celica
    Current Toys
    97 Pajero EVOLUTION
    04 Lexus ES300
    92 Hilux 2wd
    If you really want to put an EJ20 into a Toyota I'd suggest mounting it along with a subaru 2WD box north south in the back of an SW20 or AW11. You'd need to put a hump in the boot floor for the gearbox and rig up a cable shift but I think it would be a really cool conversion getting the weight way down in the chassis. Plus the engine bay is wide enough to have a chance of fitting the engine in.
    it's be just like driving a Porsche.
    Junior Member Backyard Mechanic jezza323's Avatar
    not really.........porsche engines hang behind the rear axle....and they are 6 cyl horizontally opposed
    Quote Originally Posted by jezza323
    I knew there would be some pedantic that would pick me up on 1 or both of those facts...
    what can i say....im bored
    Porsche have built cars with opposed fours, eg 356 and 914, and mid engined, Boxster.
    i dont call a boxster a porsche.......to me porsche = 911 but yes, you are right
  1. Ta23 Diff?
    By {Mr Crabs} in forum Tech and Conversions
    Last Post: 03-05-2007, 10:55 PM
  2. 1g-gte front winged sump into TA23 Sway Bar issues!
    By hemi twofifteen turbo in forum Tech and Conversions
    Last Post: 22-09-2006, 10:27 AM
  3. 1g-gte front winged sump into TA23 Sway Bar issues!
    Last Post: 21-09-2006, 11:08 PM
