Results 1 to 4 of 4
Thread: 1g-gte front winged sump into TA23 Sway Bar issues!
    Default 1g-gte front winged sump into TA23 Sway Bar issues!
    Before u say search, I have been and done many times to no avail. Plently on 1g into ra23, but not on Ta23 with front sump.
    Engine: 1g-gte air air cooler with winged front sump
    Car: Ra23 with TA23 front X-member (basically a TA23 now)
    Apparenly the front sump 1g was meant to be almost bolt in with the Ta23 xmember and correct mounts. The problem I have is the front sump fouls the front sway bar by about an
    inch. I'm confused to as it was meant to fit! (famous last words) Am I missing something obvious, or is it true I will need a custom/modified front sway bar to make things work!
    I have no mounts at all installed on the engine, just test fitted with engine hoist and jack. Still no change of it fitting though.
    Any help apreciated!!
    Default Re: 1g-gte front winged sump into TA23 Sway Bar issues!
    You are right it will not fit. When using the front sump 1g-gte with a ta23 cross member the sump needs to be modified to allow room for the sway bar.
    This link may help you
    http://forums.toymods.org.au/index.p...t=0#msg_237129
    There are also other links within the link that may give you some info you need.
    Goodluck
    Dave
    its either custom sway bar or alter the sump to clear.
    I have this problem in my ra28 and im just goin to slope the front wall of the sump enough to clear.
    Black Betty >HERE!<
    (\__/)
    livin on the edge as a Grease Monkey Snyper's Avatar
    south australia
    or just use the RA cross member and mid sump setup.
    may have a RA cross member if you're interested.
    Daily - Prado 90series
    Work - T908 620hp Cummins ISX
    Shed - 1975 TA22 2TG
  1. MA61 Part Numbers & General Infomation
    Last Post: 27-03-2013, 12:31 AM
  2. Sump position model guide (SPG#)
    Last Post: 31-01-2006, 01:15 PM
