you are correct to be skeptical - it's complete BS.
i cant remember where ive heard this before but is there any truth in it? ive done a search and cant find any info on this. im just curious if it can be done and if anyone has done it. i thought revving past 10000rpm was a myth. it would take quite abit of hard earned peanuts to create such a engine.
I've questioned why it can't be done.
Stock bike engines get well past 10k rpm, I'm pretty sure Formula 1's get to at least 10k. Why not make normal cars do that? Sure you'd need much lighter internals and a new (fast) ECU, but why not?
I'm preparing myself to be shot down in flames...
89 ST162, Extractors, Muffler, Suspension, Intake, white dials. More to come when I get money...
Originally Posted by Javal
...squeak like a rat in a microwave...
Not myth at all, US F/Atlantic 4age 16v race engine gives max power around 10,600 rpm.
Why not make normal cars do that ?
Are you prepared to pay $60,000 AUD for a 4age 16v n/a and then rebuild it every 2000klm, if it lasts that long. No grunt below 7000, can't let idle below 2500rpm.
i think formula 1's are pushing past the 20k mark.
but there is a reason that the engines only last a couple of races when pushing that kinda rpm.
and the noise is phenominal. orgasmic yes but for a daily?
1990 aerotop supra 1jzgte manual,
1990 aerotop supra 7mgte manual stripped
2003 ba xr6turbo - top to bottom build.
Originally Posted by mikie_121
the old 3lt v10's went to 23,000rpm, while the new 2.4lt v8's can do over 19,000rpm if they could (fia put 18,000rpm limit)
but there stroke is very small
5M-e........ "5 minutes of Entertainment"
2JZGTE VVTi....."WIN"
Toyota Supra 1983 Ma61
Toyota Supra 1997 VVTI JZA80 RZ
I'm pretty sure the Cosworth V8s were reaching 20k before they put a rev limit on them.
There is zero point trying to build a street motor which will rev over 10k, it's just a bad idea for many different reasons...
didnt the 2zz's rev to about 9k right before they exploded
lemme guess..
Initial D and the silvertop engine from group A racing, with the VVT mechanism disconnected and the main character not discovering that the engine can rev past 7000 rpms until someone else told him and his dad had to specify the limit?
this is from the f1 websiteOriginally Posted by The Scarecrow
and the v8 cosworths b4 this rule were touching 21k rpm i dont think the old v10's were reving much if anything past 20kEngines
Engines homologated and used during the last two races of 2006 must now be used during the 2007, 2008, 2009 and 2010 seasons. Although this move, designed to cut development costs, has been widely described as an 'engine freeze', some limited development work will be allowed. This will, however, be strictly controlled by the FIA. Engines are rev-limited to 19,000rpm.
yeah as above.
formula atlantic engines were limited to 9500 rpm some time ago
they were revved to 12500 previously
you could if you wanted make a 20v rev above 10k
its take some work though, custom rods, crank, valve buckets etc.
i dont get what you mean by top seal removal though?
please, no more PMs!
Mr Revhead - he obviously wants to spend $ZERO and get ++++hektikWATT power gains.
you wouldn't be referring to the speed sensor issue, which when disconnected, doesn't allow you to rev past 7000 rpms, and when plugged in the ECU knows you're moving and lets you rev higher up, like 8100 rpms or something?
by "top seal removal" he means he's been watching too many cartoons with ae86s drifting.Originally Posted by Mr Revhead
how to make 20v rev past 10k:
1. disable rev limiter
2. fit tacho that shows 10000rpm
3. go drifting around mountains of japan
(only joking)
