Results 16 to 30 of 57
Thread: 7MGE and ITB's?
    Junior Member Backyard Mechanic haison's Avatar
    Default Re: 7MGE and ITB's?
    Goddamn it rob. You've planted some evil ideas in my head...
    1984 MA61 - http://www.toymods.net/forums/showthread.php?t=12340
    1972 RT81 - http://www.toymods.net/forums/showthread.php?t=24160
    RObErT_RaTh - I think it's fair to say we all love the bush
    Viper_Nipplex - If bush is this popular, just wait until the boxes are ready
    Penrith BC
    i have big pics of the hydro GT linked above somewhere
    damn site went goofy and i lost a few of the bigger images
    use the gtr throttles @ 45mm - cheapest and easiest to set up, port spacing is good, and installation height is minimal
    will reply to your PM shortly
    ed
    ../delete/ban
    tech moderator
    Quote Originally Posted by haison
    Hey, someone else planted them in mine first! I'm just sharing the thought
    Quote Originally Posted by ed_jza80
    Noted, thanks for that Ed
    Quote Originally Posted by RObErT_RaTh
    Cheers again GT The 7MGE ones I believe are stock 60mm and that's just one so I'm sure 6x 43mm would still be plenty for what I need
    Not about supply but it's about runner length and velocity. Do the calcs - 45 mm is the best compromise. 43mm will very likely be too small if you end up tweeking the motor.
    Completely forgot about the GTR throttle option - cheapest by far. You can pick up the plates from SAU forums for about $150. Same concept regarding fabrication of a manifold.
    Question about putting shorter stroke cranks into an engine.
    Can't seem to get my head around this, the dude in the first post used a 5MGE bottom end with a 7M head. I'm wondering if you use a 5M crank in a 7M block (seeing as it has the oil squirters) you would have to use the longer 5M rods right?
    Ugh i think i just answered my own question typing it out..
    No idea why it is being done - WOFTAM. Yep, you'd probably need to use the 5M rods - but I can't be sure - check the deck height and go from there.
    There is a loss of compression - reduced swept volume - so you'd need to get new pistons made to get the comp back up.
    Just stick with the 7M or ditch the now 40 year design and get a 2JZGE. If you really want a smaller capacity I6, use a 1JZGE - they're practically being throw away.
    5m bottom end is used because its got a shorter stroke, less torque but higher RPM potential.
    Penrith BC
    i would NEVER destroke an engine under the assumption that you gain something back in revs...
    wrong wrong wrong
    ../delete/ban
    tech moderator
    if you were running/racing in a category that required retaining the original block but allowed induction/head changes - then it might make sense to put 7mge head onto 5/6m block? But that's pretty damn unlikely to occur.
    But my gut feeling is that they're avoiding some kind of engineering approval by retaining the block but putting a much better head onto the motor.
    hokay std 7m bottom end it is.
    Blacktop ITB's don't have a round bore where they mount onto the manifold. It would be annoying to match to a manifold.
    Silvertop ones do have a round bore.
    (\__/)
    (")_(")
    Forum Sponsor Conversion King
    wrong wrong wrong
    i dont think they would do it for the revs thing but more to build a long rod motor, ie get a set of longer rods made to bring the ve up in the top end of the rpm range.
    this would also allow higher revs @ the same piston speeds also.
    but i agree with what your saying i would prefer a big cube torque monster over a revvier engine
    but its all personal preference
    linden
    gtr throttles are close to dcoe spacing but the studs are in a different pos from memory.
    Yay! I'm an Automotive Encyclopaedia Hydra's Avatar
    I wish I hadn't looked at this thread, it reminds me how much I want to see 6TB's hanging off a 2JZ in my car.
    Jun 2007
    It may be wise to find out what the exact flow gains are. I know that on a full-race N/A 1UZFE, ITB's only allow 15% better flow than the standard Manifold, so in that case (for street use) it would be wiser to just have the stock Manifold Extrude honed and/or larger t/b then to mess about with ITB's.
    Quote Originally Posted by abently
    try telling ed that and he might think twice about the money hes just wasted or not.
