Page 10 of 16 FirstFirst ... 89101112 ... LastLast
Results 136 to 150 of 227
Thread: $250 vented brake upgrade for KE30/35/55 also celica/corona
  1. #136
    C'mon, Touch My Grease Monkey SLO-030's Avatar
    Feb 2009
    Default Re: $250 vented brake upgrade for KE30/35/55 also celica/corona
    I'll be doing this to the front of my 30. If i have a working camera i'll take a few happy snaps along the way.
    Member Of The Leaf Sprung Axle Trampers Club
  2. #137
    Mar 2008
    Quote Originally Posted by SeptemberSquall
    with the mx62
    - steering arm to strut bolt diameter?
    - if above NO, using mx62 steering arm, ball joint to steering knuckle taper?
    i reckon those two will fuck you up
    what length is an mx62 strut body and how does that compare to your std one?
    i've found that the body length of the strut is actually about 10mm shorter from memory.
    problemo was the the steering knuckle. the bolt spacing is out by about 2mm...
    so my solution was to leave the front locating dough in the knuckle and ovalise the rear most bolt hole to allow it to fit.
    now i haven't driven the car nor will i for a long time but i believe that it will work as i have had a mate do the same thing and it was fine for him. but i will look into using the mx62 steering knuckle or somethiing that will fit... maybe if the taper is wrong a bit of machininhg could make it fit?
  3. #138
    I am not yet a Grease Monkey RA23's Avatar
    35rolla, if you are still looking for XT130 gear, check out Harveys. About 4-5 or so last time I was there.
    Quote Originally Posted by 35rolla
    hi i asked you a while ago about this upgrade and dont mean to be a pain, i cannot for the life of me find an XT130 at any wreckers, i have looked around and just wondering if you know of any reason why i cant use cressida front assembly's from a late 80's model? they have same stud pattern and look to be very similar to the struts you have pictured.
    Projects: No project cars left ...
  4. #139
    Feb 2009
    I went to the local wreckers (U-PULL-IT).
    Got the XT130 struts, RA60 discs and MX62 calipers. went to go pay for them.
    Guy adds it all up seperatly and it comes to $180. Apparantly all a strut includes is a shock and spring.
    I went back today and pinched the calipers off them and left the strut and rotor there.
    Just thought id let the people in Adelaide looking to do this to source parts else where. Toyoland sells complete strut pairs for $100.
  5. #140
    Sexy ******r 1st year Apprentice PuttPuttBang's Avatar
    Oct 2008
    Hey mate, Nice write up.
    Curious to know whether this will also work for a ta22, seeing at ra28 would be the same setup
  6. #141
    if you can confirm that XT130/RA40/RA28 struts fit into a TA22 then i dont see why this couldnt work.
    Good luck.
  7. #142
    yes it does
  8. #143
    Certainly does work, as Ed (shelldrake) has this setup in his TA22.
    ([][][]II--LT--II[][][])
  9. #144
    Sydney N.S.W
    i have a set of KE lower control arms used for this setup. Helps with camber issues.
    i did not require them for the ra28 upgrade. available on request.
    edit. no longer AVAILABLE
  10. #145
    Mar 2009
    Im looking to do this brake upgrade on my TA22, only problem is that ive
    already got new front shocks for the TA22 strut. The questions is; will the TA22 shocks fit into the XT130 struts? I bloody hope so cos if not ill have to sell the new shocks
  11. #146
    I believe the TA22 shocks are narrower in the body diameter than the XT130 struts unfortunately...
    Shouldn't be too hard to find a buyer for your shocks though in the for sale section!
    Now - RA23-WRX
  12. #147
    some spacers would be the ticket then yes?
  13. #148
    Junior Member Grease Monkey ta22 3tgte's Avatar
    Sep 2008
    I had standard TA22 strut inserts in my unmodified XT130 struts, worked fine, but they will need a spacer in the bottom of the tube, as the inserts are not quite long enough, some fat washers thrown in the bottom worked for me.
    Cheers Brendan
  14. #149
    Mar 2009
    Ok so spacers in the strut bottom will fix the length
    [QUOTE=SilverRA23;1045717]I believe the TA22 shocks are narrower in the body diameter than the XT130 struts unfortunately...
    Whats the best way to fix the diameter problem? Another spacer type deal?
  15. #150
    Nope, no way of fixing the diameter problem, other than using a smaller diameter shock. XT130 is a 48mm OD shock, and TA22 45mm OD
    By The Witzl in forum FAQ
  2. Aw11 st205 GT4 Front Brake Upgrade
    By safeforever in forum Engine & Driveline Conversions
    Last Post: 21-06-2007, 10:25 PM
  3. AE86 Brake Upgrade - Here is what I did
    By Sprinter in forum Tech and Conversions
    Last Post: 01-02-2007, 10:26 PM
  4. AE86 Brake Upgrade Options
    Last Post: 07-04-2006, 02:29 PM
