Cheers for the PM, ive got the right ignitor, but i think the wreckers must have given me a later model dizzy, i should be going back tomorrow and i should get the part number.
Brendan
well i've sent the PM.. so please ring me, as there may be info i need to add here for others..
Q:- part numbers for what..?? the coil, igniter, rotor, plugs, what..???
if i know i'll find this out & add to my thread..
But in short.. the igniter on the 1981 thru 1985, 21R & 22R motors only have 2 x wires in the single gray sheath... & the 1986, 22R has 4 x wires in the gray sheath to the dizzy....
You can only use the early type..
Project: '82, GA61 XX
Brendan
Daily - 1994 JZA80 Supra
Weekender - 1976 RA23 Celica
Past - 1990 RN105 Hilux 4x4
Ring me it's easy...the ph # is in the PM i sent...
But if your dizzy has 4 x wires in the plug then it be the wrong one..
Note to All.. "yes" i'm still here & if people want i can find these parts as a Full kit for you to do this mod'... "yes" Full kit that is all parts listed in the 1st section of this thread..
i've just not done this conversion for some time.. & i've had a few people want me to do it but still not heard back from them ..one day i'll get to do this mod' once more & add the missing info..
P.S. i do still have a box full of parts to do this mod' i just don't have a full kit..
Thanks, I've got it all hooked up and working very well.
hmmmmmmm.....
You have not rang me & well did you use the fish tank tube.. ???
Hmmmmmm... i think not...
So ring me... as your dizzy will be out of wack.... with out the fish tank tube....
edit: post removed by hks7mgt
1973 TA22 'Go-Fast' Celica
1970 MS55 'Go-Slow' Crown
Committee Member of CCCSA http://www.classiccelicasa.com/forum/index.php
[email protected]
yes we have spark !
used an sv 21 module ( and my 18 rg electronic dizzy ) that had no module attatched
working backwards .....
tried another one first , which had many wires
no joy
i think 2 of them needed to go off to the computer......
worked on the bench with a bike battery
thanks again ,the wiring diagrames really helped
Remember this is a recreational activity ......
we got toys ! 83 lo lux in matte black..... amazingly 18 rg powered , one day it will run right !
the dinosour 90 gsx r 750 with ohlins and yoshi , and the dirty little secret 125 vespa ,4 speed and kick start
"what do you do with the fish tank tube"
you need 4mm to 5mm on the main shaft........& well every body else has just PM'd me for a ph number....
"also you have connected one of the two wires coming out of the noise suppressor what do you connect the other two" ......???????
look at the wire diagram.. both are conected.. & shit you must have long wires if you think that you can mount it on the side of the dizzy...![]()
one on the left came with a 22r and the one on the right came with my 18rg now im not sure which plug runs to the 22r dizzy i was assuming it was the long wire on the left coil but on the right hand coil that wire is cut short and the other wires are used for the dizzy plug.
not sure whats going on here im not great on auto electrics and seeing as i didnt see it setup beforehand it really isnt helping
RT104 with 4AGTE
Some assembly required
lowlux. The wires cut short are the two for pickup in distributor i.e red and white wires. If you have distributor nearby look at plug on pickup you should be able to see colours of cables at back of plug. remember also pickup cables are usually sheilded to reduce interference.
yup your right so the one i need for the dizzy was cut short...brilliant! now to find out where the other two wires go.
RT104 with 4AGTE
scoured the wreckers today they only had one st141 and it had a 2sc but no coil all it had was the condensor so i need to know how the other wires are joined up and how they end up +ve -ve and tach as i wasnt lucky enough to that section of the harness
RT104 with 4AGTE
anyone care to shed some light on where these wires join up?
RT104 with 4AGTE
