Results 1 to 12 of 12
Thread: 2T/ 3T carby
    is certainly not a Automotive Encyclopaedia suss_slide's Avatar
    S.A.
    Default 2T/ 3T carby
    hey guys, do any of you know if these carbys are any different? im might be able to get a 3t carby sonner then a 2t and im jsut wondering if the 3T will do the trick.
    Another question is does anyone know if the earlier TA22's came with a different carby then the newer ones? cos i went to the wreckers yesterday and the carby i bought was slightly different. By that i mean the part were the throttle cable i believe hooked up didnt have a lil stopper bit. does that make sense?
    Now targeting, people who are now targeting!!
    S.A.
    Default Re: 2T/ 3T carby
    i got one more question, the tube were the spark plug goes down into the cylinder, usually filled with oil in two of the spark plugs, this is because some seal is broken, can anyone tell me were i can get these seals new from?
    P.s. im talking about a 2T motor
    Quote Originally Posted by suss_slide
    Any auto parts store or Toyota.
    Emo Slayer Backyard Mechanic rollin_stock's Avatar
    South Aust
    suss-slide, i think you have to get the tubes themselves from toyota, about $40 for all 4, not too expensive.
    Classic Not Plastic Domestic Engineer ace's Avatar
    I've read countless times that the T, 2T, 3T, 13T etc (i.e all the single cam versions) have the same inlet manifold bolt spacing etc so the carbies are interchangeable.
    I've never proved this for myself though.
    Ace
    My TA22
    Quote Originally Posted by gianttomato about new cars
    Yeah sure, it goes alright and it's got air conditioning, cup holders and automatic tampon removers, but where's the charm?
    Photographer and Backyard Mechanic Rinmax's Avatar
    I would think that a carb for a 1800 engine will have larger fuel jets than that for a 1600 engine. I don't think it would be a major prbolem but could make the car run rich even with the best tuning you do.
    I encountered this when we put a weber from a 2ltr Cortina on a 1600 Gemini one day. It was way too rich and although it was running it was undriveable. I have only tried this once though so could be an isolated problem, and re jetting a carb isn't too much trouble.
    Best of wishes though and let us know how it goes.
    "It's an ingenious solution to a problem that should never have existed in the first place." - JM
    "A Ferrari is a scaled down version of god while a Porsche is a Beetle with mustard up its bottom." - JC
    S.A.
    well i'll prob just get the 2T carb, Ace have u ever encoutered any problems with ur spark plugs being covered with oil were the lead connect? Im thinkin that this could also be a cause of the poor fuel economy but the carby guy said that it wasnt anyhting elecrical but jsut the carb, what do u guys think?
    Just a leaking seal causing the oil in the spark plug tubes, common problem. Just clean it all out before you pull the plugs out.
    cheers Chuck.
    MS51Crown Coupe,
    S.A.
    Do you guys know if toyota still sell these seals, im thinkin of taking the rocker cover off and replacing them with newies, do you think this would be a hard job, is it more effed up then it looks? have you done it before?
    Repco / Auto Pro sell these seals. 10 x 10mm nuts and the rocker cover is off! easy as.
    For first timers, label your plug leads with a bit of masking tape, from the front 1 through to 4 at the back.
    cheers Chuck.
    MS51Crown Coupe,
    S.A.
    i went to repco they told me only toyota sell em, when it comes to taking the rocker cover off, is there anyhting else ill have to remove to get to those seals or will they be visible?
    Celica man 1st year Apprentice Toy_T-18's Avatar
    Tasmania
    it is all very simple just undo the bolts to the rocker cover and pull it off. were the spark plugs are there should normaly be a black ring looking thingie, they can also somethimes still be stuck to the rocker cover, right were i have pointed.
    yes toyota still sell them and also you can still get them from any other large outlet. but normaly come with the new rocker cover cork gasket, unless its a rocker cover witch has a gasket like a K series engine around the bottome of the rocker cover
    also i didnt read if u solved this problem but the 2t has a smaller carb than the 3t if you are to use a 3t carb you need a 3t intake manifold because the stud patter on the 3t carb are larger
    and thats my 2 cents
    Cheers Sean
  2. 3T Versus 3T GTE conrods
  3. 2t dies when normal engine temp is reached?
    By jeffro ra28 in forum Tech and Conversions
    Last Post: 21-07-2006, 08:18 PM
  4. 2T vs 3T Oil Filters
    Last Post: 12-06-2006, 02:08 PM
