Results 1 to 9 of 9
Thread: 2T Head and 3T Block, standard items - any problems?
    I'll think of something.. Backyard Mechanic -NiCkeL-'s Avatar
    Default 2T Head and 3T Block, standard items - any problems?
    Hi guys,
    I need to replace the block on my standard 2T in my TA22. The thing blows a huge amount of smoke and I don't want to drive it again as it is. I've been looking around for a while now for a replacement bottom end without any luck. I have found a good condition 3T bottom end (from a T18) - is there any problems bolting on my head from my 2T to the 3T block?
    Anything that needs to be swapped, replaced, or anything to look out for?
    Also, are the camshafts the same? I've got a mild cam from a 2T...
    Any help, advice or anyone who's got a good condition 2T block would be appriciated!!
    no backyard Domestic Engineer japlish's Avatar
    Default Re: 2T Head and 3T Block, standard items - any problems?
    All should transfer over from the 2T, Nickel.
    The rumor is that the 2T head may raise the compression ratio a bit. Not sure of this one without measuring the combustion chamber capacities.
    If you have the time and cash have the 2T head cleaned up and if standard when they face it get 1mm taken off to raise the compression.
    All your good 2T bits will go into the 3T. The cam should make the 3T nice.
    Pick the better looking/less worn bits, such as; rocker arms, rocker shafts, push rods and make up a set of good cam followers from the 16 you have. Use the lighter flywheel of the two.
    Regards
    Rodger
    the heads are the same casting, will be no problems!
    Better get this sorted quick Nickel - You need to make the cruise on Sunday!
    Quote Originally Posted by jezza323
    The heads are NOT the same !
    Yes they will bolt up fine but there are variations in the ports and combustion chamber size. Rodger ahs covered everything you need to worry about in his post above.
    Rod.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    Awesome! Good news guys. The head has had good money spent on it, but the block is completely fubared!
    I'll get onto this now guys - thanks for the advice!
    Quote Originally Posted by shelldrake
    I wish I could - just no time! I'll get it sorted out asap though..
    Hey Nickel,
    If you ever get a Dyno done can you post the results up with details here:
    http://www.toymods.net/forums/showthread.php?t=14661
    Would be good to add one for this motor set up.
    Regards
    Rodger
    Last Post: 29-02-2016, 12:30 PM
  2. Cooling Systems - Overheating Problems.
    Last Post: 24-06-2006, 09:40 PM
  3. Matching your head to your o-ringed block.
    By PHOBIA in forum Tech and Conversions
    Last Post: 09-05-2006, 03:14 PM
  4. 5M-E head on 5M-GE block
    By CrUZida in forum Tech and Conversions
    Last Post: 30-03-2006, 11:42 PM
