Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 149
Thread: Brake Upgrade - XT130/RT132 Strut with Nissan Alloy Caliper - Research Stage
  1. #46
    Default Re: Brake Upgrade - XT130/RT132 Strut with Nissan Alloy Caliper - Research Stage
    well if Linden would stop sleeping in til 7pm id have these
    call me linden .... ill plan for photos up here Tuesday all.
    Black Betty >HERE!<
    (\__/)
  2. #47
    Forum Sponsor Conversion King
    Here we go:
    Disc clearance - XT130 Strut - R32 GTST Disc - 8mm machined hub
    How the caliper sits ... note the ears interferring with the disc etc
    Rotor and caliper comparo
  3. #48
    RA23/28 Strut with caliper bracket (mock up for fitment only - not final design), disc and caliper. 8mm shaved off rear of hub still.
    Also how it sits inside 15s and 16s
  4. #49
    +rep cause ive seen it and its hell sweet .... wished id researched more before getting C/P/H
    Black Betty >HERE!<
    (\__/)
  5. #50
    i got the bill for the brackets today and while a little pricey you have to remember that they started off from 50mm steel so there was a lot of work involved. ill put pics up when they are all bolted up.
    total machine work inc hubs discs and brackets came to $560 but whenyou think about it it will still be under 1k for the setup so its not bad.
    pm me if your interested in a set.
    please note these are for 23/28 struts and is the only big thing you will fit behind 15s for 1k, if you have 16s then i can put something else together for 2/3 the price.
    linden
  6. #51
    ok lets see hat you can put together for 16's for 2/3 of the price,.... that i will be interested in,
    what calipers are you making these kits work with?.....R32 or R33?
    very interested linden!....the mx83 idea is dead!
    have you got a 16" kit there already that i could have a looksy at?
    blake
  7. #52
    Linden, is that hubs, discs and caliper brackets for $560? Or have I jumped the gun there...
    If that's correct, then add $250 for calipers and you have a very good brake upgrade for $810!
    ([][][]II--LT--II[][][])
  8. #53
    Quote Originally Posted by twentyEight
    calipers $250 new rda slotteds $275 bendix ultimates $120ish new braided lines $250ish
    + $560 for brackets and machining then your done. obviously if you use better discs and pads it will be more or if you use S/H stuff it will be cheaper.
    but for around a grand it will stop like it hit a tree and do it consistently.
    linden
    ill do the kit for the 16s next week as im flatout with cars atm.
  9. #54
    well im deffinately hooked for a 16" kit, will they be designed to be used with the R33 caliper?
  10. #55
    yep, that way if you wanted to fit r34 gtr brakes later on then it will bolt straight up.
    i dont like mixing disc/caliper sets as it makes it a pain to upgrade later.
    linden
  11. #56
    so it will use a r33 rotor aswell! nice, i'll grab a set of calipers today/tomoz
  12. #57
    Junior Member Backyard Mechanic celicaboy_2000's Avatar
    Very interesting, I'm in the process of sorting out some rt132 struts but after reading this I am very interested in the 16" kit. Awsome work investigating all this +rep point for you Linden. One question tho, will it pass an engineer OK?
    Matt
  13. #58
    Quote Originally Posted by celicaboy_2000
    Matt
    considering that most of the cars i do are street cars then i have to make them legal (and i wouldnt like to think of the consequences if it wasnt)
    not so much investigative work more like customer gets what customer wants (so i had to do it ,not really optional)
    the 16" wheel kit will be 29?mm r33 discs (30mm thick) and calipers from the same r33 but if you wanted to use r32gtr discs (32mm thick) and calipers then they will bolt on to the same brackets as would r34 brembos with matching discs and much bigger wheels. this is to suit the xt132 strut and hub.
    i will also let you know how far the caliper sits out from the hubface and then this will let you know what wheel clearance you need.
    linden
  14. #59
    r33 is 296mm x 30mm i believe,.... would you happen to know the size of the brembo r34?
    i'll have a search around...
  15. #60
    i believe that there 324x30mm the same as the r33 brembos.
    linden
  1. R32 Nissan rear brake caliper
    Last Post: 31-12-2014, 10:58 AM
  2. mx83 brake upgrade; my pics
    By PlacentaJuan in forum Tech and Conversions
    Last Post: 04-02-2011, 09:21 AM
  3. Toyota equivalent for Ryco Z145a Oil filter
    By optionUP in forum Tech and Conversions
    Last Post: 02-09-2009, 11:04 AM
  4. AE86 Brake Upgrade - Nissan style
    By CrUZida in forum Tech and Conversions
    Last Post: 15-10-2006, 07:13 AM
  5. break upgrades/ta23
    By buztoy in forum Tech and Conversions
    Last Post: 14-10-2006, 08:00 PM
